Negative resistance via pyroclay.com material ?
Started by hartiberlin, October 02, 2007, 10:25:37 AM
RadiantEnRg
@Linda...I tested it with an multimeter....power supply V output is regulated by a 30V cap....Never goes above 27v...So believe whatever you want. It's BEMF spike that powers arc...SIMPLE AS THAT...this ENERGY IS FREE....made by "near" instantaneous change....Thats the fact of the matter.
I haven't read all the other posts...and am late for class will read up later
RadiantEnRg
@Armagdn03 yes that is a wonderful explanation....I couldn't explain it any better :)
@argona369...here's the thing about speed f light, it would seem that only whatever makes up voltage potential(be it "aether"...etc) travels at the speed of light...and it is proven that electrons move at "near" the speed of light. This makes sense if you think about what an electron is suppose to be...it's an sub-atomic particle....it has a tiny bit of mass...(b4 you say anything, I know we are taught to disregard this because it's close enough...or we are taught it's massless all together "I am making the crazy assertion that physics as we know it is not whole!!!!") Voltage potential is completely massless....or at least much closer...so voltage can beat electrons if we can switch fast enough.
@Everyone saying it just throws the regulated power supply out of regulation.....it's only regulated by a transistor that pulses a 30V cap via sensing loop!!!...so if I can get the motor going and the spark gap going(these are separate..ie not at the same time "meaning 2 tests")....they will harmonize with the pulsing!!!!! Not out of regulation....In sync with regulation!!!! Here is the un-changeable thing. The output is physically isolated from the 120VAC...both by an opto-isolator, and by a step down transformer that charges a 30v cap for supply power!!!...I would also like to stress, I had a 3rd party member of my H2Earth skype channel come out and take measurements!!!! Maximum voltage ever recorded from output was 27V!!!!!! PERIOD, game over!!
That's 27 volts supplied to microwave xformer....and 27v supplied to the small motor...funny thing is the big motor which is symmetrical in commutator construction DID NOT SPIN AS FAST, NOR WAS IT 27V!! IT WAS LESS!!
Get over it....sawtooth wave makes a HUGE BEMF spike..... /|/|/|/|/|/|/| .... violates no laws of physics..I am not saying xformer draws in energy..(only open circuits do that at resonance)...all I am saying is the normally grounded Back EMF is very powerful and we should start using it!!!!....Radiant energy is something else I am working on....nothing to do with motor...except the motor was COP>1.....(i believe it was resonating at the exact same pulse as the output "fluxing" the electrons to create EMF in motor coils....after all these are coils...off pulse of commutator is a sharp change in time!!!!)...oh one more thing, just to be clear.....Motor is ran w/o microwave xformer.....just power supply and motor fo that one!!! Power supply and microwave xformer for the spark gap test!!
RadiantEnRg
Now, I am not saying anything bad about anyone here, I get why you must challenge/question things, it is how to prove/disprove stuff, after all we were all taught differently in school. I am a mechanical mind(who is just now learning digital electronics) and that is why I can see "how" this works(pure physics)....however, I don't have time to explain/defend my findings here, I am working on a deadline for another project and I have classes every weekday. So I will probably not come here so often to defend/explain my tests...Take them or leave them, I really don't care. I don't intend to become famous...blah, blah, blah...I truly just wanted to show people there "may" be another side of electricity that was frozen out of the market long ago. I would encourage people to start reading Tesla, and watch the Bearden videos..better yet buy his books,....He has a great new book out.....Awesome!!!....but ya, I might pop in time to time to see if anyone has any questions/ideas for me...But, I would encourage you to just buy the power supply off of Ebay.....Or just start taking them apart...Once you know what to look for, you will see that many are constructed this way and can be used for the sharp off spikes...If you have a scope it's that much easier...look for either a sharp Ton...or sharp  Toff (you will most likely find sharp Toff).....but here's the thing....it needs to pulsed by a sensing loop.....this makes synchronization easier!
Models that have worked so far: ADP-25HB, ADP-16B (I believe it's 16B)
Basically all Delta ADP power supplies...and an HP worked after I pulled out the ground....but experiment...Go to your local electronics recycler and look for rectangular power supplies...in the 14-30V .8-1.2amp  range..open em up and right away you will know...(you will see a large cap....a small step down transformer....and then a small cap on the output...it will also have an input choke, and an output bifilar choke.....So get some power supplies and take some measurements yourself (I have nothing to prove here)....You may be very surprised!!!
RadiantEnRg
Oops...One more thing that will make your replications work :)
I didn't get these results right off the bat...I was pulsing a cap by hand, over an over, soon I noticed that a patchy "corrosion" started to appear...I kept going, until this was larger, and then.....Low and behold it started arcing...so whatever that layer is it is beneficial,,,,I believe its a p-n type heterojunction diode (negative resistor diode)
But ya thats it...final post for awhile, good luck hope you get results
linda933
Quote from: RadiantEnRg on October 11, 2007, 09:27:07 PM
It sounds as though you are not interested in subjecting your "facts of the matter" to any testing or to considering any theory except your own to explain what you observe.  Why do you bother to present your experiments, then?
All I am telling you, and others are saying the same thing, is that your demonstration could be much more convincing and get a lot more people interested if you simplified it by using a battery instead of a switchmode power supply and it still worked.  That seems pretty simple, and since you are already in posession of these magical beads, why not do the simple battery/bead/motor video demonstration and really get the interest going?  Lots of us would really like to see that, if you could do it.
Linda
