Negative resistance via pyroclay.com material ?
Started by hartiberlin, October 02, 2007, 10:25:37 AM
RadiantEnRg
Simply pulsing will not work!!...resonance needs to be found...and then adjusted to new resonance when arc forms...THAT IS WHY POWER SUPPLY IS SO SPECIAL....no other reason!!
linda933
Sorry if I seem too stupid.
Let me see if I understand what you are saying:
1.  The reason you do not show us a motor speeding up with the bead while using a battery supply is that it won't work.
2.  The reason it won't work is that the battery does not provide the essential sawtooth waveform.
3.  The sawtooth waveform is a small-amplitude high frequency AC voltage riding on top of the mainly DC voltage (27V) that your power supply puts out.
4.  Your theory is that this high frequency sawtooth waveform (otherwise known as the ripple voltage, present on all switching power supplies) resonates with the bead somehow and causes a large boost in the power delivered to the motor.
Is all of that correct?  Am I getting it finally?
Linda
RadiantEnRg
When the power supply is on with no load....it is silent. However, when shorted, or when arc forms, or when the little hobby motor resonates...The circuit hums....Indicating resonance!! RESONANCE RESONANCE RESONANCE RESONANCE RESONANCE RESONANCE RESONANCE RESONANCE RESONANCE RESONANCE RESONANCE.....getting it yet??????.....You build circuit that can pulse a  coil and can automatically find...then maintain resonance and no matter what input voltage(within reason to application)....you will be in business.
linda933
Could you slow down for the retarded here and just indicate if the four points I made are exactly correct understanings or not, please?
Then, after that, could you tell me about this :"hum": and if its audible or what...
Thanks
RadiantEnRg
Close Linda...
The reason I have not showed it with a battery is
1. Because the lil motor that auto tunes to resonance is destroyed...the arc melted brushes/commutator after long use.(no problem, because all lil hobby motors are constructed the same way...having 3 coils/3commutator contacts/2brushes)
2. Because I do not have the skill, nor money to build my own 12v oscillator circuit, with it's own PLL...(Resonance alters due to load, and needs to be matched) All I can build is a simple astable  555 circuit with crude pots to adjust...which wouldn't be so bad on motor...(I need another motor)..however..i have a HUGE project in the works, which will prove this all on a much bigger scale
3. I have many small 12v batteries....I have drained most of them :(
4.I am simply not working on it right now. I have an analog resonant coil I am building now, I plan to prove all of this further....using around 110Kv :) (10 12v batteries in series pulsed into transformer....for all you battery people)...
Linda I know it may seem like I am dodging your curiosity....I am not, I took measurements, and would love to show you guys again.....so in the meanwhile, i am going to go to FreeGeek..an electronic recycler, and pick up some power supplies, they have a whole huge box of em.....then i will post videos with scope data k??...at least till I can get to batteries
