DISSOCIATING WATER, A KEELY Project
Started by hansvonlieven, October 03, 2007, 02:04:46 AM
h20power
Verification of frequency to produce etheric force from water?
A recent (1965) possible verification of the frequency Keely used to dissociate water into etheric force was related to me by a scientist when we were discussing certain aspects of free energy. He wishes to remain anonymous for obvious reasons, but his name is on file. I have no other verification of this experiment, however I believe it merits telling. The scientist, I shall call him Dr. X, was doing experiments with ultrasonic sound in a column of water. The object of the experiments was to devise a means of separating various densities of materials by injecting them into a column of water which was subjected to an ultrasonic standing wave vibration. The experimental setup is sketched in Figure 3-3 (for BBS considerations a description follows). A Barium Titanate ultrasonic transducer  was fixed to the bottom of a quartz tube which was closed at the bottom and open at the top. Pure water was poured into the tube and the water column was "tuned" so that a standing wave was produced at 40,000 CPS (cycles per second). The transducer was powered by a 700 Watt power amplifier  which was driven by an ultrasonic frequency generator. Because of the large amount of power put into the column of water a certain amount of evaporation took place at a constant rate when the transducer was energized. Therefore, to maintain a standing wave in the water column a feedback device caused the frequency to be raised as the water evaporated and the temperature changed. As a test, Dr. X decided to run through the experiment with only water in the tube to ensure that a standing wave was maintained as the water evaporated and the frequency rose higher and higher. When the experiment was started everything worked beautifully. Dr. X took periodic readings of his instrumentation and was assured that the standing wave was being maintained. Suddenly, with no warning whatever the water disappeared from the open quartz tube. He looked up thinking to see the water splashed on the ceiling when to his amazement a clean hole went right through the ceiling. The hole was the same size as the inside of the quartz tube. Further investigation showed the hole continued on through the roof also! Dr. X checked his notebook and found the last frequency entry to be 41,300 CPS. It was shortly after this that the water disappeared. Because of the time interval between the last reading and the disappearing water, the frequency sent to the transducer was higher than the last reading and Dr. X said it could well have been very close to 42,800 CPS, the Keely dissociation frequency. This obviously dangerous event caused Dr. X to dismantle the equipment and try some other approach to his problem. This experiment points the way to the use of our modern technology in conjunction with Keely's laws of dissociation to change matter into energy without the use of radioactive materials or extremely expensive atomic accelerators."
Now here are some transducers that just might do the trick:
http://www.massa.com/datasheets/18A-40%20Datasheet.pdf
http://www.massa.com/datasheets/tr89.html
And some reading for those interested: http://www.ndt.net/article/yosi/yosi.htm
Cat_Tinka
Motorcycle Runs on Water - Auckland NZ
Link...:
http://www.youtube.com/watch?v=FW_LQqJk740
inventor poures the water through an invention,before pouring it to the fuel-tank
what happens here ???????????????????????????????????????????????
this is John
Pirate88179
@ Hans:
I would like your opinion on the motorcycle running on water video just posted prior to my post.
I find it interesting but a bit strange.  It appears legit but it is very incredible to me.  Can someone
alter the structure of water such that it will burn like that?  I am curious as to why he makes such small quantities.
@ Cat_tinka:
I had not seen this video before you posted it.  Thank you for doing so.
Sprocket
According to a Panacea video, they contacted this guy for info and was told, paraphrasing, "the technology is no longer viable in the current economic climate..." - if you have watched the video above; it seems his paranoia was justified - he was obviously made an offer he couldn't refuse!
Nice world we live in...
hansvonlieven
Quote from: Sprocket on May 14, 2008, 08:17:33 PM
Was that a flying pig I just saw?????
Hans von Lieven
