quick idea - will this work?
Started by snowblind, October 04, 2007, 01:13:19 AM
Freezer
armagdn03
Good creativity!
Capillary action is a very interesting phenomenon,
The "sticky" point comes in removing either the water, or the mass from the top of the capillary tube. The same hydrogen bonding (vander wal forces) that creates the force, holds onto the water, or object at the top. Meaning that either you have to waste extra in removing the water or object from the tube, or leave it be....to be fueled by a secondary source, that receives its "extra" energy from else where. Nature has a wonderful solution. Its called transpiration, and it can be found most notably in trees. The extra, comes from the sun.
I wish I could turn my brain off sometimes, then I could get some sleep.
shruggedatlas
Quote from: snowblind on October 04, 2007, 05:43:44 PM
Hello
sorry
it was a quick idea.. i realised this a couple hours after i posted it that it will not work.
sorry! i keep trying.
I know you admitted it would not work, but I am not sure if you realize why, exactly. The concept is called Hydrostatic Paradox. Most of the water in the large tank does not push on the water in the pipe at all.  It pushes down on the bottom of the tank instead.  Only the narrow column of water directly above the pipe mouth actually pushes on the water inside the pipe.  This is why there is not enough pressure on the water to lift it back to the top.
The following webpage explains it pretty well.  Note especially the striking example of the Hoover Dam holding back Lake Mead.  Whether the Hoover Dam holds back Lake Mead, which is 115 miles long and 600 feet deep, or instead a hypothetical Lake Mudd, which is also 600 feet deep but only 115 inches long, the horizontal pressure on the dam is exactly the same.
http://scubageek.com/articles/wwwparad.html
casman1969
Here's my two cents worth..,
Take the original diagram and enclose it in glass or whatever, then submerge it so that the highest point of the outside water is above the top of the return/feed tube then we could place that feed tube with say rubber hose and put it outside the the enclosed tank. Would the rubber hose not react to the difference in pressure from outside to inside the tank thereby moving the water up????
In a half baked mood right now....
FreeEnergy
Quote from: casman1969 on October 31, 2007, 08:53:02 AM
how about a drawing? thanks :)
