How it all works
Started by darchorse, October 07, 2007, 10:36:41 PM
b0rg13
so ,.. how to tap energy from a spark gap ?...pros/cons?.
if you want to get out of the rat race,you have to let go of the cheese.
sm0ky2
Con: a continious status-arc gets hotter than the sun. and will melt our electrodes.
so we can only "tear the universe" for short durations.
sm0ky2
It would seem, that this 'tube' would simply be an extention of the input/output of the 'valve.
if the valve is capable of passing a controllable stream of energy through its 'opening', then the rest of the tube would (simply put) be a connection of 'valves' in their fully open position.
z.monkey
Howdy Y'all,
I forgot about this thread, and started another one with basically the same topic.
http://www.overunity.com/index.php/topic,4429.0.html
Anyway I am modifying my Soft Particle Reactor to use a relay to provide the spark gap.  It's a four pole relay so I will really have 4 spark gaps in parallel.  Plus I modified the driver circuit to be a DC to DC converter, store the high voltage in a big cap then use the relay to discharge the big, high voltage cap through the Reactor (basically a transformer).  I having trouble with the trigger circuit right now.  I should have some results in a few days.  Here's the link to the Soft Particle Reactor information, pictures and schematics.
http://www.overunity.com/index.php/topic,4255.0.html
Fun with arcs and sparks...
OK, Mo Later...
Goodwill to All, for All is One!
sm0ky2
 it may have some % chance of tearing  an enourmous hole in the fabric of space, and destroying the entire universe...
       <erk??>
i wouldn't mind an uncontrolled tap, provided you could "pull the plug" if it got out of hand.
and close the tear.
then you could use the resistance of your circuit as the control, rather than a 'valve'
