Teslas electric car
Started by armagdn03, October 11, 2007, 11:18:19 AM
truesearch
Vinyasi
Quote from: truesearch on August 13, 2022, 12:14:02 PM
Source for 6" copper spheres:
https://www.amazon.com/Robert-Manufacturing-Spherical-Diameter-Buoyancy/dp/B008OMIWJ2/
It looks like they also offer a 5" size.
I posted a question to the seller asking if the threaded nipple has an opening to the inside. Thanks.
Vinyasi
One more version...
This time, instead of finely powdered silica or calcium ferrite strewn throughout the interior of each noble gas-filled hollow copper sphere, this dielectric substance is melted onto the underside of each copper sphere as a thin layer separating each copper sphere (acting as the outer plate of a capacitor) from the virtual inner plate of each of these two capacitors embodied by the neon (or, other noble) gas.
This inner plate is virtual due to the ionization of any noble gas behaves as a negative resistor. I am using the term of "virtual" the same way that Eric Dollard uses it to imply "grounded in the virtual realm of the complex field of numbers". This is where negative resistance arises from: the vacuum, i.e.: non-existential state of matter (equivalent to a black hole or dark energy in physics).
I'm sharing two versions of possible builds since I'm groping. ;-)
Here is another location from which to download the screenshots and the simulator files...
http://vinyasi.info/mhoslaw/Parametric%20Transformers/2022/Aug/?C=M;O=D
Yet, more versions to ponder predicated upon the idea that maybe the copper tubing extends the noble gas into both spheres. And also, the dielectric layered onto the inner surface of each sphere may also extend along the entire length of the tubing?
Micro-Cap simulation file...
"ammann with solar capacitance, v2d.cir"
https://ufile.io/qyv7dzjx
Bob Smith
There's a lot of focus on the antenna(e)/rods. But I seem to recall J Bedini speaking about the lead acid battery as a kind of antenna for drawing in aether/cosmic energy and transducing it into electrical charge. I've been away from the bench for a couple of years getting an off-grid homestead up and running with my wife. However, I remember seeing my DMM on my 6V  lead acid battery go pinging off the scale (over 1000V) when the circuit my LAB was running hit the proper frequency. I very much believe that negative resistance is important here, as Vinyasi points out. This, in my experience, seems to appear when a large enough resistor is inserted at the proper place, coupled with a resonant frequency comprised of sharp transients.  This seems to stress the dielectric/aether, and cause the battery to act as an antenna. At this point, the circuit becomes load-driven, not battery charge driven.  In this sense, it is no longer a closed system, but a deliberately open system, which actively involves the interplay of the aether. I think this may be what Tesla was doing with his pierce arrow setup.
I wish I could be more specific, but my stuff and notes are still in boxes from our move.  Lot of work building, harvesting and prepping for the winter.
Maybe then (winter) I'll have some time to get back to all this. In the mean time, I drop in and read when I can.
Respectfully,
Bob
