F.B.D.I.S.S.M - Flux.Boosted.Dual.Induction.Split.Spiral.Motor.
Started by Honk, October 11, 2007, 02:30:42 PM
casman1969
Honk,
Thanks, that's one mistake I won't have to make....
Carl
helmut
Quote from: Honk on February 25, 2008, 05:30:37 PM
OK, thanks for your positive words, the few readers I seem to have.  :-\
I'll post an update on the result from the solenoid Permenorm alloy core during this week.
The heat threated samples will arrive on wednesday. / Honk
Honk
You have more readers as you meight think.So am i very interestet in your work.
And i do not want to post useless comments on your forum.
But i enjoy reading about your progress.
So please keep it up and have succses.
helmut
Prophmaji
Use a layer of stacked silicon grain oriented steel (0.35mm thick or less-good transformer steel for high frequency wide band audio transformers) to 'pop' the field flip between the two in the photo. It also provides a polarized shear which cuts and intensifies the interactive area, with regards to the 'flip' of the shear area..
turn induction into capacitance.
remember, a field must march up the lenght of the coil wire and polarize..thenthe circuit completes..then  a current can flow, in a conductor..this propagates at light speed, or at the given rate of conduction in the given material.
This means an inductor is a 'near lightspeed' capacitor for that short interval before the 'poalrized' alignment  is complete, and current flows. Laminates and the coils in use here will behave the same way.
Which is why tuning and timing must be so precise. Utilize the collapse of the organized field. This is how Joseph Newman's device works. Aetheric fields. or, background noise and random organization. The voltage field runs up the wire at near light speed, organizing the electron orbits along the way and when it completes the circuit at the other end.. conduction of the organized field occurs..and we have inductance/currrent considerations. JUST before that..we have a length of wire with an organized field which desires to collapse, if the circuit is not completed. He strengthens the field intensity via magnets and rotation..and away we go. Long wires, huge fields, rotating magnets...great timing..and boomsey!..we have horsepower out---with no draw. Just collapsing fields.
The same considerations need to apply to all magnet motor attempts that use laminates, rotation, coils, electricity, etc.
The thing to understand is that capacitance, inductance, voltage, and current are all actually the same thing, with different applications and existent reciprocals.
It's all application of a polarized differential, one with static and or elastic tendencies.
Low-Q
I also look forward to see the result. I however expect to see an amount of output that is at most equal to the input power, as the only thing that keeps the motor to run is the presence of a solinoid... This far I still don't understand how the magnets will add energy to the system. I would strongly advice to remove the magnets, and then measure the results. I would expect the output is greater. The question is when you have spent this amount of time with your project, it is for sure a risk to try something that might prove you wrong...
Never mind my scepticism. Good luck with your project, and keep up the good work :)
br.
Vidar
ecc
Any News?
@ Honk
It has been while without any news about your interesting project. I hope you have not given up and that the project is still going ahead.
ecc
