AhuraMazda
@Localjoe,
They say a picture can tell a thousand stories but I can think of a thousand questions. Of course any information you can share about your diagram, positive or negative will help us all.
AM
Localjoe
.. I randomly found it on the leedskalin page.. I didnt take it from someone ???  Anyway , It didn't show much info, there was a video on the site labeled induction test or something , it just looked visually similar to your project with the open ended transformer leads and all.  And the ground magnet made me think of a few things this could be used for, so i figured id just share, thats all. :)
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Peterae
Here;s a picture taken from Tesla's Papers regarding a single wire motor.
amigo
Quote from: RStiffler on November 29, 2007, 09:33:47 AM
Although not explored, there are times I have during many straight hours of testing that I thought I saw 'Diurnal' effects exhibited from the circuits. In one case a self-running oscillator that would run for 30+ minutes at night, would not run during the day. This was NOT the result of any type of radio interference so we won't even go there. This is an area that needs looking into but must be done in a controlled way to insure you use the exact circuit under the exact conditions, including your ambient temperature and lighting conditions. In my case when using 1N4148's it was even necessary to paint over the clear glass so the they did not react to the light.
This would be interesting if someone did show such effects.
Thank you doc, at least I'm not going crazy to think this then. Unfortunately I do not even come close to having necessary facility or conditions to conduct this kind of an experiment, but I strongly feel that there is something there.
Furthermore, thank you for the heads-up on the 1N4148, I will use a black marker to shade them in and see what happens. Will also try some other diodes that are in solid black packaging and hopefully note a difference between the two.
Have you ever considered that LEDs can also detect light and possibly produce some potential/current in the process (albeit minuscule amounts if any) but I have seen other unrelated projects where LEDs are used in conjunction with micro controllers as light emitters and detectors. These ones came to mind Multi-Touch Sensing through LED Matrix Displays and LED as sensors.
Kurt Hoffmann
Quote from: hartiberlin on October 11, 2007, 05:28:41 PM
Have a look at this:
http://www.youtube.com/watch?v=OJvFd3pYBnM (Stiffler removed it from YouTube)
Amazing !
I hope Dr. Stiffler will publish the exact circuit.
Regards, Stefan.
P.S:His website is at:
www.stifflerscientific.com
Check out http://67.76.235.52/drstiffler/ce4.asp and http://67.76.235.52/drstiffler/buildup.asp
