Perraultium
@ BEP
Not looking to start a flame war here but maybe this will refresh your confused memory:
Quote from: BEP on October 14, 2007, 09:43:31 PM
Quote from: Perraultium on October 14, 2007, 05:37:01 PM
As far as posting very little experimental detail - why should I bother repeating something I did 20+ years ago? If you don't believe something said then either ignore it or prove/disprove it to yourself.
the B and the P in BEP stands for something you wouldn't understand and most likley wouldn't believe. As in callsigns - BEP was a substation of a network. The B stood for Berlin............
And in both instances you suggest that I replicate the OU circuit you won't post. Kind of a catch 22 don't you think?
Oh, and you do go my multiple identities to congratulate and promote yourself and we have watched you do that for years
My comment stands and you stand corrected.
BEP
This really becoming a bore.
I still don't see the word 'from' in front of the word 'Berlin'.
You are insulting someone I don't know thinking he is me.
You say I've suggested you replicate something when I all I've done is try to provide advice (granted I was too loud and free with theories and past experiences in the beginning).
What OU circuit, that I won't post, are you talking about? I've said many times I haven't succeeded in creating OU. Since I allowed my thoughts about this stuff to go public, JUNE THIS YEAR, I haven't succeeded in anything that hasn't already been posted by folks here.
The recent one that I related to this failed after 4 days when I closed the loop (WITH 2 AAA BATTERIES). That is just about as long as the batteries should last. Why should I post scope shots on that?
This is only the second username I have used. The only way that can be confirmed is for Stefan to starting looking at server logs. I'm not going to bother the man about that.
Enough. I have better things to do. What's up? You didn't like my opinion of what a magnetic field was?
armagdn03
I think we can all agree this is neither the place nor the time. Respectfully stop please. No hard feelings either way towards anybody.
I wish I could turn my brain off sometimes, then I could get some sleep.
bolt
All of these circuits have several themes in common. Incidentally i highly suspect that ANY ferrite or even a coil wound around a paper tube will work given enough turns its just a simple transformer and there is no need to go looking for special cores.
For example the bedini circuits use coils and blocking diodes to minimize current drain on the primary but rely on the wheel rotation to produce the coil spikes. Well instead of that this circuit runs the output coil into RF resonance and works very similar to how i suspect the tpu works. Certainly the frequencies used in the couple of megs range are precisely where i would expect these effects to happen given the size of the coils and caps used which is why i suggested several times those banging with audio range pulses may not get anywhere when stable RF is required in the low megs range. In addition the use of open ended coils has been demonstrated many many times and patent in some cases Tesla of course and other like the Russian single wire longitudinal transmission system which has an open collector coil and the German scalar wave demo which also a simple PCB 200:1 transformer running to open collector Xmas tree ball antenna :)
The latter for those that seen that video use 4.2 meg RF carrier and i think 7 megs to produce the scalar and the received energy has been calculated and replicated to be a least 180% and in some cases reportedly 1000%. Now in each case the skeptics argue that the input power is not measured properly to cover the suggested output power and John Bedini followers know this problem all too well despite the fact it been shown several times that an RF generator fed into a wave guide of at least 3 nodes will produce longitudinal scalar waves and the output voltage AND current is higher at the output even when fed into a carbon resistor and temp calculated.  Now the problem with all these circuits is there is no feedback and the excess power tends to be very low.  There will always be loses but non of the useful gain is fed back to the input. There is no such thing as a lossless circuit his control circuit and coils may need 50 or 100 Milli amp to run all the time. Only the tpu can be seen to have true feedback because once you work out how to do this the device is then free running and the arguments then change from "he is not measuring the input correctly" to "must have a dozen pp3 batteries inside".
Likewise its no accident that Meyers water split almost certainly used a Bedini open collector type circuit floating output coil connected to resonant tubes through wave guide longitudinal chokes setup as nodes. When you do this and everything rings just right the power on the tubes will appear MUCH more then an equivalent DC circuit. Its unlikely he ever made a self powered tpu but very likely he achieved gains of over 500% compared to DC.
So these circuits are real they do exist but for most of the they don't concern anyone too much as they have little real practical use other then lab tests and if they threaten to leave the lab then MIB pop round.
