minesapint
I lashed up the circuit from the doctors website using a hand wound coil and a sig gen.
What I found is that the circuit behaves just like a tuned circuit as you would expect - resonant at 2Meg and 10Meg.
I could not light the LED without a ground, it would even work with a high Z ground (finger etc...)
My analogy is that the driver is a RF generator and the LED circuit behaves like a crystal radio.
If you've ever played with a crystal radio you'll know you need a ground and an aerial.
A crystal radio is not OU despite it gets power from the 'aether'.
I really can't see anything special with this circuit. Ok, so I have only spent an afternoon on it and I maybe missing something.....
Oh well.
Bruce_TPU
Quote from: minesapint on December 12, 2007, 06:29:53 AM
(snip)
Oh well.
@minesapint
Hardly an accurate replication attempt, wouldn't you agree?  Please use the coil core that was specified by the good doctor.  Very skilled people have been working on this for months.  Now the doctor reports twice the power out as in and you simply say, "Oh well." because you could not make it work?  Back to the bench....  ;)
Quote from: dean_mcgowan on December 12, 2007, 02:00:43 AM
I have one more question.
How does one observe a circuit's ability to interface with the Spatial Lattice and Cohere additional energy?
Regards,
Dean
@ Dean
I took that statement to mean that it did not produce more power out then in.  If the circuit interface's properly you will know it because OU, additional energy, more power out than in, what ever you want o call it, is there and verifiable.
If it does not interface properly, then none of the above.  That is how I understood that statement, anyway.   ;D
Holiday Cheers,
Bruce
DrStiffler
Quote from: dean_mcgowan on December 12, 2007, 01:55:51 AM
Please, I am not attempting to take anything out of context and please correct me if i am wrong, however these two statements within a paragraph of each other, both relating to the "Thomas Oscillator" seem to contradict eachother. One claims OU and the other I interpret to state otherwise. Which is correct ?
"Thomas Oscillator is able to provide a considerable amount of energy to the load, although
as with the Thomas circuit I have not observed the circuit's ability to interface with the
Spatial Lattice and Cohere additional energy."
"The preceding 'Thomas' oscillator as shown will drive the common SEC coil
to an OU of +2 when using 36 White LEDS. The input current is a small
40mA. This is a great oscillator and simple to build for work with SEC."
ref: http://www.drstiffler.com/drivers.asp
Regards,
Dean
You are correct this statement is in error. I do my own programming now and did not remove this statement when I moved the drivers to their own page. Sorry I'm not Perfect....
All things are possible but some are impractical.
DrStiffler
Oh well.
Apples to Apples, Oranges to Oranges.
Gee! I have spent 10 years..........
allcanadian
