0 Members and 31 Guests are viewing this topic.
dean_mcgowan
I don't think you are nuts either.
Though video 10 with the closed loop would be a boon  ::)
Cheers,
Dean
xee
@ Dr. Stiffler,
Good luck in your research and please keep posting your results.
DrStiffler
@All
A new driver named in the honor of Bedini for all his work in the FE pursuit was provided to me by Mark McKay, PE. The diagram of the new driver also includes the test and evaluation setup used by Mr. McKay to explore various SEC circuits. As seen in his title, Mr. McKay is a qualified engineer and is making every effort to replicate in a conventional scientific way the SEC effect and determine if indeed it is new or conventional.
Take a look at his setup, it shows the great care that is required to produce accurate and meaningful measurements from a test circuit. As can be seen, it is no small matter to test these circuit configurations, yet as Mr. McKay has shown, it is or should be possible.
Thanks to Mr. McKay and Bedini for the inspiration he has provided Mr. McKay in the quest for finding new energy forms.
All things are possible but some are impractical.
xee
@ Dr. Stiffler,
I know you have spent a lot of time working on this so you probably have already thought of this. But, I would suggest you put the whole circuit with battery in a metal box, such as a school lunch box or cookie tin, with a tight fitting metal lid. Then use two filter feedthrus to bring the rectified DC out of the box. That way all of the RF energy would be trapped in the box and measurements could be made without any RF being induced in the LEDs and test equipment. I have already spent more time on this than I planned so I do not wish to try this myself.
AhuraMazda
Why has it gone so quiet in here?
@DrStiffler
I was put out a bit at the efficiency figure of 81% with the "bedini driver" then I noticed the light output has not been counted for.
Also, I personally don't trust digital meters in these instances.
AM
