0 Members and 28 Guests are viewing this topic.
emitremmah
Hello Doctor,
I am still hanging around. Until I get a breadboard there is little I can do?
This is the first electrical setup that has interested me as it should be fairly simple to replicate and perhaps get exited over.
About your last vid, you showed what occurs with only the rod and with the original 2 winding coil.
What about a 2 winding coil without a core. Is the ferrite required for saturation or capturing of the magnetic flux to generate the frequency.
It is as though this is an RF receiver and transmiter and also a step up transformer. More like an RF step up transformer without external power requirements. But what little I know about electricity is 100 time more than I know about RF.  All I know about electricity is if it doesn't work get another battery.
An empty cup
allcanadian
@RStiffler
The videos are very interesting, it is a pleasure to see good quality video for a change.
When building these circuits it should be considered that the quality of current has changed, our views of "current" are polarized in that we assume the current must be closed loop returning to its source. The currents produced in the secondaries however need not follow the laws we have created for ourselves. The currents become relative to everything, that is they can move to seperate isolated circuits, to grounded plates, to ungrounded plates and depending on the potential and period of oscillation act as a unidirectional current. I have asked a question many times in other threads---- what do you call a high frequency/high potential impulse?--- DC. But this "DC" is only one half of the potential difference, the earth ground can provide the other half ,having no relevance to the source battery or the primary circuit----- open loop. It should also be noted that the practice of  "isolation" ensures the working circuit can never effect the source, so in this case many of the laws we apply in conventional circuits no longer apply.
Best Regards
DrStiffler
Quote from: allcanadian on January 18, 2008, 10:00:37 AM
@RStiffler
Best Regards
Sir!,  that is very well stated and from my point of view, 'A very accurate understanding' of some of what is taking place in the SEC circuits and others that the conventionalist's are turning away from.
There is a massive flow of energy around and through everything in the universe (including we humans) and because the earth is such a large dynamic mass it can indeed be or appear as a focal point for some of these energy flows, yet it is only a focal point or conduit if you will and is not the actual source.
Why do I get the feeling that you 'been there, done that'?
Thanks for the accurate and allied posting.
All things are possible but some are impractical.
DrStiffler
@Ben K4ZEP
Thanks again for pointing out the resolution of the regulated supply, although in this case it has no relevance, power was not discussed nor was that the focus of the video although a little timing on the lamp burst can answer questions not asked.
Well I don't think the neon on the primary coil has much at all to do with the coupling, see the next video's and you will understand why.
@All
I need to break video #9 into a number of smaller vids so I can get them posted and change my layouts for the demo's, so don't think I have lost it when you see 9.0, 9.25, 9.5, 9.75 still saving that magic #10  :-\
There is a prior post by (allcanadian) that has said it very well indeed and really better than I have to date, look back a few and be sure to read it.
allcanadian
I took these snapshots across the capacitor in a circuit Im working with, wave 3 is a picture of what happens when things go right, the small wave is the "current" everyone else uses---- the big one is what I utilize indirectly----- the other "current" everyone ignores. Wave 2 is a picture of what happens when things go  wrong, which is usually what happens in my case. ;D
