0 Members and 23 Guests are viewing this topic.
Gustav22
Hello Dr. Stiffler,
thank you for the latest video.
edit: I deleted some questions which were based on my wrong understanding of the circuit.
money for rope
hartiberlin
Quote from: RStiffler on January 23, 2008, 10:08:36 PM
I will upload a diagram 'here' tomorrow, seems can not upload a tif and I am on a UMPC  that only does tifs.
Hi Doc,
I enabled now TIF upload.
Please let us know, why you can use this now
without the ferrite cores.
Does it even run better with the ferrite cores or more bad ?
Many thanks.
Regards, Stefan.
DrStiffler
I'll try ONE more time to get the site to take my post, it goes to NEVER LAND...... BUMMER
Here is the circuit diagram of the circuit in SEC video 9.75. Working on the web site to try to get it closer to where I am at this time, although doubt I can get to this point.
Quote from: hartiberlin on January 24, 2008, 04:54:18 AM
Hi Doc,
Many thanks.
Regards, Stefan.
@Stefan
Thanks for allowing tif's, I now work a lot with the Samsung UMPC when not close to the main network.
The core issue has been addressed already both in this thread and on my site, but here it is again. This research started from ECAT or Energy Conversion by Articulated Transfer, a paper by me on how to access the aether (if you will) and obtain new untapped energy and convert it to a conventional electron flow. ECAT evolved into SEC or Spatial Energy Coherence, not much difference in what it all means, except that the SEC Hypothesis supports the concept of 'Energy Nodes' within a 'Universal Energy Lattice' that can under the correct conditions be tapped and new energy extracted into a useful form.
During the early years of ECAT various forms and configurations were used to explore tapping this universal (Spatial) energy lattice (Nodes). This ranged from 'Polyphased' coil configurations 'See my site' to work with Xenon Plasma. During this work the AV Plug was added at which point the whole direction took a new path. Until now it was not understood why the Plug seemed in certain circuits to produce small excess energies. It is now known that it is a function of the junction capacity of the diodes (explained in a paper someday). When the research continued with coils it just so happened that the 'Antenna' coil was used in a few tests. This resulted in some very interesting results that could not be explained by the AV Plug diodes alone. This took me down the road to thinking the core and a composition of BaFe may be what was producing the result.
Again only after hundreds of additional hours of working with the circuits was it determined that the core was not the reason, it was indeed again a condition of capacity to the 'Spatial Lattice' that was allowing the coupling and excess energy. Research continued to where I am today, finding that it can indeed be done in a much simpler and effective way (without the core) and using a 'Parasitic Grid' around the power coil. This was two fold, it removed 90% of the loading on the 'Exciter' and it dropped the AV Plug output impedance from around 10Meg ohm to ~20K ohm.
Hope this helps you understand. Someday when I can stop the research which still sees almost daily improvement, Papers will be produced and available, yet this will not happen until I can call SEC a Theory.
Keep checking the Stiffler Scientific  web site for information. There is 'No Way' I can post it here. I only try to keep you all current by theses postings.
All things are possible but some are impractical.
hartiberlin
Hi Ron,
are the scopeshot in your 9.75 video from the pickup coil alone ?
Why does the amplitude get bigger, when the
AV plug cap is almost charged up fully ?
Does it then radiate more into the pickup coil ?
Regards, Stefan.
EMdevices
