fritz
Quote from: Freenrg4me on October 20, 2007, 04:16:46 PM
Hey fritz - Is there really such thing as a "proper" board in the search for something that classic EM can not produce or explain such a sOU? EDIT Does cold electricity and regular electricity work the same? Do they have the same current level? Etc.
Different metals exhibit different electron affinities. I think we should replicate what is being displayed and not tell Ron what to do. Otherwise, that comes across as being a bit egocentric.
You can order some cores and put it on a "proper" board and tell us how it works.
Work things out:
If I want to know what I have found - I track it down.
1.) What is essential for the operation (Ground?)
2.) What is exchangeable (can I use green LED!?)
3.) If I "reduce" the setup shortening wires, does it influences
   the circuit ? - If yes try to replace parasitary caps with real
  ones ...
4.) Is it reproducible,
5.) Everytime ?
6.) Everywhere ?
7.) Temperature ? Air Pressure ?
8.) Does it work with another pulse generator ?
"Is there really such thing as a "proper" board" ?
Yes there is.
As long as you invent a "magic board" - no need.
b0rg13
hi , is anyone able to get there crayons out and draw the circut?...in a simple way with everything listed?
..there is some kind of core?..with is it cardbord or paper wraped around it ?..what kind of wire is coiled around it?..where does each end of that coil go to ?..etc ( yes im talking about a drawing a 10year old could read with everything listed and made clear).
..and how might it work ?...the core does,what?.......vibrates?,humms?(how?)..the coil around the core then picks up the vibrations and and electrons flow to make a led light up ? ( i have noidea as you can plainly see,but id like to know).
if you want to get out of the rat race,you have to let go of the cheese.
Freenrg4me
@ B0rg13
The circuit has 2 versions. Both are listed in this thread. He also has a web site http://stifflerscientific.com
The ebay auction where you can get the cores is listed in the thread.
He also has some videos on youtube http://www.youtube.com/profile?user=MRH2O2
hope that helps.
Freenrg4me
And just in case anyone was thinking about trying this.... I was bored last night.
Fugifilm makes a new video tape made of BeFe nanocrystal material. I bought one and wrapped about 100 layers on a 1" plastic tube. Since I had no way of knowing how many windings on the secondary, I wrapped for about 2" with #36 wire. (Single strand) and then placed about 20 turns of #24 on for the primary.
I hooked a scope to it and pulled off windings, hooked a 555 to it, etc. nothing aver created anything unexpected. I.e., it didn't work. I didn't have litz wire but that probably would not have mattered much.
I am looking into getting more core shapes and sizes from the same company to experiment with. Also I found a good source for Litz wire and they sell sample spools.
If somebody knows exactly what form of barium is in a core please specify. I am thinking about getting the chemical and trying to make my own as I want to experiment with pancake coil layers to build multiple cells, if this thing pans out.
