0 Members and 347 Guests are viewing this topic.
DrStiffler
@All
@Stephan
Ok guys we have been here before, many time and before I repeat it so no one has to go search for it let me openly state this.
"I do not at this time, trust an external lab to test and (Correctly) report on SEC testing"
Why? Because of feedback and statements from labs that I was dealing with to do some tests. I would rather have "John Q Public" start out backing me up. If you do it right, you can have a very high error factor and still get a good out come. In some case you can be off by 50% and still agree with me, Then and Only Then is it safe to ask them to put up or shut up!!!!!!!!!!!!!
I have NEVER made accurate internal measurements, (for one thing something we can not measure is in there) and as Loki says and I have said and as Plengo has found, things run different with devices hung off the exciters.
Light Level; three Scientists have stated that certain LED circuits produce more light than they should with a similar non-SEC input, BUT they say SEC is NOT OU, What? What do I not understand.
I and an independent associate have both after doing extensive calorimetry found excess heat up to 5 times input, SO WE ARE WRONG??? Because CalTech or someplace else did not report this it is not true????
If even five of you show excess heat >2 with home made instruments, we can call  them down big time.
Unless there is some instrument I have never heard of, connecting a wire and reading an output will NEVER show the TRUE SEC picture. Forget the DMM's the Scopes and the SA's for now, a light meter or a home made calorimeter from foam and a glass thermometer (some digital freak out big time) we can do it.
All things are possible but some are impractical.
alan
First of all, respect for the hard work of all here, and especially, doing it for the public.
@RStiffler
"thing run different with things hung off the exciters."
Is this also the case if you vary 1 load, for instance, what happens (to the power input and visible light intensity) if you load the motor/fan with, for instance, your hand?
If this is a constant factor, you can, like I tried to tell before, load the fan or that other motor with a generator instead of the propeller, then you've got the same sort of electricity on the output as put in.
Another way is calculating the mechanical kinetic energy of a load, like a flywheel or the propeller, which will, according to conservation of energy, always be lower than inputpower, if calculated correctly.
DrStiffler
Quote from: Gustav22 on April 04, 2008, 04:45:22 AM
in reference to Doc's SEC 'electrolysis' video
http://www.youtube.com/watch?v=k1pJEz0YGlQ
Quote from: RStiffler on April 02, 2008, 05:38:27 PM
The 22uH choke feeding the AV Plug gets so Hot you will burn your finger if you touch it (from 23V@6mA don't think so). The 10uH in the collector stays ambient along with the transistor, so can anyone figure out why this is happening ;)
Hello Dr. Stiffler,
i was thinking about SEC electrolysis and have two questions:
1) how will prolonged SEC 'electrolysis' affect the temperature of the water in the test tube?
2) if a relatively huge amount of H is set free and a relatively small amount of O, then I think that the liquid (water) in the test tube would become oversaturated with Oxygen, such as a superoxide (not sure whether I apply these chemistry terms correctly).
However, will the liquid be combustible/flammable as a result?
Thanks
@Gustav22
I am not going to make any additional claims, my neck is far to short for that, to many cut downs  :(
But you are pretty much on the money, Active PhotoSpec observation is very interesting and is helping in what is taking place. It would be worth the education to try it and here are some suggestions.
1) In a single duct (as shown in the video) place a wad of cotton in the end (be sure that water level is near topped off, don't want glass flying around) If the cotton touches the water and becomes saturated, fine, you will saturate anyway.
2) Be sure to use clean SS and good distilled water, other wise you will get all sort of crap in the water.
3) Run the test for at least 15 minutes.
4) Take the cotton in the end and saturate it with water from the tube
5) Quickly lay this saturated cotton next to another new wad of cotton that is clean and unsaturated.
With a match lighter, light them both and see what happens..............
DrStiffler
SEC Exciter Parts List (down to two supplies, coils are special)
www.drstiffler.com/secexciter.asp
Buy one built and working
www.drstiffler.com/
