DrStiffler
@Plengo
You did a great job on the videos, how or should I comment, well great work.
I do think that you might be a bit less sensitive if you removed some of the stray capacity, simple like maybe get it on one board and shorten the wires. Otherwise you got it all running. Looking forward to your battery test, I have not had meaningful results trying this, but I have plenty of hope.
I would like some additional info on what was going on when you turned your scope off to change the SEC operation? If I understand you had no physical connection to the device, you removed the probe and ground???
I'm interested as it fits well into my theory, but I have not experienced a similar even as yet. You could mail me direct as its not pertinent to the thread at this time, just might help with my paper.
Thanks for all the work.................
All things are possible but some are impractical.
powercat
Quote from: RStiffler on April 07, 2008, 11:10:39 AM
Quote from: alan on April 07, 2008, 08:49:35 AM
Quote from: RStiffler on April 05, 2008, 02:47:25 PM
Quote from: alan on April 05, 2008, 11:21:47 AM
What is wrong with my idea of putting a generator to the motor to convert the event to regular current, since no-one is responding to my comment?
@alan
Hey, nothing is wrong with your idea, but it is not as simple as it sounds. Obtain a generator with know specifications, devise a coupling method. The RPM method the was proposed does work and is simple to implement. To bad EMDevices had his feelings hurt, guess mine could be, but his could not, anyway it was a good idea and only took a short amount of time to try.
When you get to the mechanical things a whole world of additional problems pop up and sometime, like with me, I'm not a great mechanical person.
Thanks, don't get upset, great idea.
Yeah, easier said than done, especially forum observers have easy talk.  ;D
Wish I could do it myself, but it is hard to work without a scope, still going to give your work a try in the near future.
Before, I asked if slowing down the fan has any effect on the inputpower, do you know if this is the case or do you want to try it? If it does not affect input, then that is a hint to overunity
@alan
My motor can be restrained and fully stopped without seeing a difference in source input, I hope some of the others will answer you also on this. There is of course a difference observed when the motor is connected and disconnected, this is a load matching difference, also the removal of the motor with out removal of the choke it is across will affect the brightness of the following LEDs.
Hi alan & doc
Generator,  maybe a small stepper motor..(used in old computer printers)
Plastic DriveShaft to avoid interference.
I got this on generating electricity with stepper motors    http://www.c-realevents.demon.co.uk/steppers/stepmotor.htm
Are there any results on running on 12v DC or 24v DC ?
Can you run more then one motor ?
Loving the SEC Exciter
pc
aluka
@ Loki
Yes you are right, i think. i?m thinking that the diode is creating an electical vortex, two diodes in different direction are creating flow!
do you know the vortex tube? or Maxwell?s devil? Two temperatures from one tube. You have to create the same effect with the diodes and the SEC. I made a Photo with a neon tube conected only by one side for you. We are all looking right now ( remember the TPU is  a turnig magnetic field).
aluka
@ Dr. Stiffler,
Yes it shines brightly and much more..... The plasma ball is driven by 4,8V Batteries ( negative resistor...) I think this circuit sucks energy to the plasma ball where the electron vortex increase the draw drastically. The voltage is very high even without fiscal connection. On another bigger model it reaches easy 700 V. The basic difference to the SEC  is that it needs no tuning because of the drag of the electron vortexes.
the grey meter is a magnetic field analyser. It drops when there is flow !! i can not explain this till now. When the Voltmeter try to measure the little neon switch off. When you touch the open end it bites...:) and it shines brighter.
here some photos
1. The first just as you asked, it works fine.
2. not touching the neon
3. touching the neon
4. trying to measure voltage and the electric field strengh
Loki67671
@aluka and All,
Sweet! That is quite interesting! I have been playing with driving a high speed Cockroft Walton using one of my SEC boards. I'll have more success maybe now that I know what I have to do with the capacitance. Plasma is awesome and I'm betting it won't be too awful long before I have my heat output very close to Dr Stifflers. 109F on the neon and 110F on the 22 uH choke tonight with 83F on the transistor and 80F on the 10 uH coil. Running 23.25 VDC / 46.5ma input from DC supply measurements not optimized via short leads and additional decoupling. I'll be investigating this in preparation for calorimetry runs along with sensors and DAQ's. I have a lot of work to do. Keep it up aluka! Very Nice indeed!
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
