Loki67671
@All,
Todays experiment results:
Circuit is SEC exciter in the currently stated configuration
Power input = 20.12VDC base coil tuned to draw 43ma from supply
22uH choke terminated in an empty connector row 90 degrees directly away from the Osc and power rails, 2+ inches
Within 10 seconds the choke was getting very warm....at between 11 to 13 seconds I opened the positive rail
Not doing so would have caused the inductor to open.
I will have to test this component now to see if its value is still the same, after the heat  ;D
Secondary test test,  ;D same configuration as above, new choke
voltage measurements attempted across choke with fluke 179 DMM
measurements taken +on collector side -on pad termination side
results:
13 VDC Input         current=29ma   current drops to 23ma with meter loading      observed quick positive voltage drop decay to zero
15 VDC Input         current=32ma   current drops to 26ma with meter loading      .002 VDC drop measured on choke
17 VDC Input         current=36ma   current drops to 34ma with meter loading      -.004 VDC drop measured on choke
20 VDC Input         current=45ma   current drops to 44ma with meter loading      -.011 VDC drop measured on choke
Voltage went negative in relation to initial condition indicating current reversal and flow into choke from the parasitic.
I burned my finger.........again!
Best regards
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
DrStiffler
For those of you who have ordered boards for the first May delivery, WE ARE ON TRACK!
The components arrived today (seen in the following picture). The boards are still 1.5 weeks out should be no problem. The LEDs are on the plane from Hong Kong.
We pulled some sample Neons to test, these are the big 1.9mA units and they work great. You will be happy!!
I did not expect so many orders for the full board, but a second order is coming by air with more chokes. There are a few left if you want them shipped on or before 5/15, after a couple of days we will have to set a new date for the next release as it will require more PCB's (2 week lead time). So if you want one with the first group of people, don't wait to long or you will not get it shipped until the end of May.
All things are possible but some are impractical.
DrStiffler
Quote from: Loki67671 on April 15, 2008, 06:59:07 PM
@All,
results:
Best regards
Jim
@Loki
Were you  using an RF probe on the meter? The values you show look right but my RF probe across the choke shows 185Vpp.
So you don't think you have a lock on burned fingers I thought I would show you my finger  ;D
amigo
Hey Doc,
Have you seen this video perhaps? http://www.youtube.com/watch?v=95ThCLkzi0I (from this thread http://www.overunity.com/index.php/topic,4494.0)
They are using simple tea strainers one inside the other as an electrode(s). Perhaps you could try this with the SEC since I remember you used SS wire for your HHO experiments, and strainers are basically SS mesh...
DrStiffler
Quote from: amigo on April 15, 2008, 07:29:58 PM
Hey Doc,
You don't think they may have seen my work in 2005 on electrodes; www.stifflerscientific.com/electrodes.asp where I used an SS strainer as shown in the following picture.
