0 Members and 23 Guests are viewing this topic.
Loki67671
@All,
SEC exciter last configuration for heat
        Neon temp       =122F
        22uH temp       =91F
        transistor temp =87F
        10uH temp       =86F
Ambient temperature =80F
Input Voltage            =18.1VDC
Input Current            =63ma
Input power              =1.14w
I'm going to test the relative heat distribution and output temperatures of these 4 components running on the new back plane through the DC voltage range that the Ne bulb fires, starting at 6.25 VDC, and then try to "tune" the parasitic C of the mounted breadboards by adjusting mounting screw tensions and possibly shims. The idea is get as close to 7.5pF parasitic as closely and evenly distributed across the nodes as possible and then remeasure heat through the input voltage range again. Always tuning for maximum subjective Ne illumination. Circuit stability is also greatly improved. More to follow and more heat to find. Now to look for the SWEETEST of spots. We'll see. Neon's are really cool in the dark  ;D Unless you touch them. Anybody else making heat?
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Loki67671
@Dr. Stiffler
Woops! Spoke too soon! Knew it would be great and make heat!  ;D
Nice work
Jim
DrStiffler
@All
After soldering this many SEC Exciter Boards, somebody should know how to solder  ;D
All things are possible but some are impractical.
samedsoft
Quote from: RStiffler on April 18, 2008, 09:38:51 PM
@All
@Dr. Stiffler,
   Do you have any plans to manufacture these boards in Europe?
   We have facilies to manufacure and send through EU. Please let me know if you are interested in low cost manufacturing base in EU region.
      Best Regards,
      Nuri Temurlenk
      MSc EEE. Automation Engineer
      Mobile    : +90 533 501 7166 (GMT +2)
      Fax        : +90 262 349 6454
      Web       : <http://www.erelgroup.com.tr/> www.erelgroup.com.tr
      Adress   :  Yeni Golcuk Yolu No 64 VezirCiftligi Mevkii
                       Kullar 41607 Izmit KOCAELI TURKEY
