0 Members and 23 Guests are viewing this topic.
amigo
Quote from: RStiffler on April 28, 2008, 09:28:21 PM
Meili has some problems and if you do not have a metal shop and some ability at working with RF then it should be considered a hobby unit. I think I put about 7 hours into metal work, they do not understand square and needed some modification. The electronics has another 10-12 hours into it, but now it is a fair unit for a grand plus some work. If you plan on getting one, I would say no unless you are going to get into it (maybe deep).
Are you saying that you had to mod yours to get it working the way you wanted? If so then it's definitely not worth getting for a hobbyist like me.
Any other units you could suggest that can do up to 1GHz (I know you hate questions like this but humor me, please, since I'm clueless about spectrum analyzers)?
DrStiffler
Quote from: amigo on April 28, 2008, 10:07:43 PM
That is what I mean. First mine would not stay on as the metal work was so bad the switch kept popping out. Then a ribbon cable passing thru the chassis was shorting because they had sharp
metal edges. Had to add friction clutches to freq and marker controls. They are ten turn pots and were free wheeling, could never adjust stable. The tube is weak, dim if you will. Yes they drift unless fixed.
They do not care either.
Try looking at the Hameg
All things are possible but some are impractical.
hartiberlin
Hi Plengo,
just watched your last SEC battery charging movies on youtube:
http://www.youtube.com/watch?v=8iju4w7lLM8
Are you saying you can charge the 12 Volts battery fully
from empty with 13.8 Watthours of energy and then it contains 1200 Watthours of energy ?
(12 Volts x 100 Amphours= 1200 Wattshours of energy)?
Great video, how do you connect your pickup coil and what kind of wire is on it ?
Regards, Stefan.
P.S. My SEC circuit did not yet come in.
hartiberlin
@Doc
nice new videos and explained very well.
Is the second neon in the last video showing a  beat frequency ?
Loki67671
Quote@Loki
Looking for a Window into you coming quantitative results.
Well I guess its my theory so I can call it what I want
Yes, the quantitative results, I'm working on it and also looking forward to that.  ;D
Of course it's your theory and I'm not making fun of the name. I like standardized nomenclatures!  ;D
The water vessel is my hold-up right at the moment but I will find a solution to that problem also. Zinc has about the same specific heat as copper, I wonder????
Besides I haven't even started debugging the and shielding the sensors or DAQ's. Much to do!  ;D I need some technicians.  ::)
I'm going forward as fast as I can.  ;D
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
