0 Members and 18 Guests are viewing this topic.
DrStiffler
Quote from: samedsoft on May 05, 2008, 02:52:50 PM
Quote from: RStiffler on May 05, 2008, 01:40:22 PM
@All
Part#1 on how I built my calorimeter.
http://www.youtube.com/watch?v=TBrgPi4_Fqk
@Dr. Stiffler
  I have been thinking about the theory behind excessive heat observation on neon gas excitation at special frequencies, at given gas volume and pressure. And makes to build a bigger neon lamp and build bigger  SEC exciter.
   Can you comment on the nature of Neon gas excitation?
   Do you think it is ball lightning happenning in Neon lamp?
   A bigger neon lamp can be used for steam production? And house heating?
   Best Regards.
   Nuri Temurlenk, Turkey
@samedsoft
I had hoped my paper would be published by now, but as always when you want something there is something that gets in the way. I am involved in some edits now to make everyone happy, seems if to left field a theory, no one would read it. So we are trying to mainstream it and yet not ignore the truth.
No I will not comment other than what you find now. Yet don't discard your ideas.
All things are possible but some are impractical.
DrStiffler
Quote from: nickle989 on May 04, 2008, 11:07:18 PM
Well finally after a bunch of blown transistors and I have finally come up with results that burn the fingers without blown-up my transistor.
First pic is the waveform.The probe is after the variable choke and the ground is hooked to the negative.  This form seems to give me the greatest results so far.
Second is the of the Voltage and Transistor Temp ...
15.3 Volts 0.04 Amps
31 C / 89 F
Third is of 22uH Choke
74F
Fourth is of the Neon
145F
At the last is the Board Layout - I have seperated the power input off the board.  The large pin board that I was using seemed to have to much capicitance and I was getting termal runaway on the transistor when the neon was at its brightest.  At least this is my take on it.  I am sure the Dr, has a better explanation then what I can offer up at this time.
@nickle989
Could you please take a close up of your base coil for me, damn I want to see that thing...........
DrStiffler
Quote from: Loki67671 on May 04, 2008, 04:14:39 PM
The stainless steel vessel and $2.00 yardsale vase. Flowers in it! Huh? In any case the calorimeter is coming together. More soon.
Best regards,
Jim
@Loki67671
Hey, with that big glass cooker you showed some time ago and the current graduated item, is it 'White Lightning' you are cooking up in that basement of yours?
Loki67671
Quote from: RStiffler on May 05, 2008, 03:03:17 PM
Best regards,
Jim
@Loki67671
Doc,
You know good and well I use copper.  ;D
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
DrStiffler
Quote from: Loki67671 on May 05, 2008, 04:03:06 PM
Best regards,
Jim
@Loki67671
@Loki67671
Well glad to hear it, you know they say its all in the taste and the copper rules.
Doc,
