mudwump
Dr. Stiffler,
Would you please post your input parameters for voltage and amps regarding the xenon tube experiment. I did not see them on the video.
Thanks.
nickle989
@ all ... sorry have not posted anything in awhile ... I have a lot going on at the home ( rugrats and summer ) front right now.
That being said ... I have some very very intersting results that I will be posting with some vids on hydrogen and more power .... I have mutated my frankenstein even more.   The original SEC that I received provided more insight.   Very cool stuff.  I can say this though that one needs to be cautious of the RF freqs be imited via the neon's or led's.
If one gets the notion build a cacudeus coil and run it off the av-plug ... BE CAREFULL ... and make some observations ... near and far ... that is all I will say and nore will I offer more then this ever.
@ loki nice work is all I can say ... once I settle down I will work the program.
Lattice333
Hello All,
first post. Dr Stiffler thanks for all the work and effort you have put in. I'm sure many are following your work.
Photo's of SEC15-3 replication on prototype board is attached.
General comments for those replicating SEC15-3 on prototype board are;
- try to copy the layout of the components on the board. The layout is deliberate.
- The Dr sources parts from Jameco - transistors are Fairchild rather than Phillips and tend to have higher average gain.
- Coil was replicated using nylon building fastner cut to length and hollowed out with drill. 5.6mm outside diameter. Used 60cm of 24 guage wire. Two ferrite beads on tapered matchstick for core. Second matchstick holds both in place. Crude but works fine.
Dr - eagerly waiting to see SEC-30W circuit. Keep up the great work.
PCB
@DrStiffler
Thanks for the SEC's and the additional item of SS wire. I've prototyped the published circuit from your website of the SEC-15, and while I've successfully driven non-linear loads (multiple LEDs, neon) in various configurations, it's not clear to me that this circuit can drive resistive loads. Have you had  any success in this area?
PCB
