DrStiffler
Quote from: Lattice333 on July 06, 2008, 08:59:51 AM
Dr Stiffler and friends
Can I ask a question please?
I remove the neon from the SEC15-3 board and the output of the choke is connected to a remote AV plug+neon via a single wire. The remote neon is lit until I close my hand around the single wire. When my hand holds the single wire the neon is extinguished. What is being blocked by my hand?
thanks
Lattice333
Humm.... Why do I get the feeling I know you?
So you have not considered the fact that you are detuning the exciter with you body mass with what has now become an antenna?
Just a thought  :D
All things are possible but some are impractical.
forest
Quote from: DrStiffler on July 06, 2008, 02:52:39 PM
Just a thought  :D
Dr Stiffler,
Is there any sure method to differentiate possibly two events : de-tuning SEC exciter from shorting  energy path to the ground throught the body mass ? I saw strange effect (I wish  someone could confirm it) - touch one neon lead and light vanish,restart circuit,then touch another lead and light seems to become stronger.WARNING! I DON'T RECOMMEND DOING THIS! IT HURTS!!!! ANYWAY DO NOT DO IT LONGER THEN A SECOND.I feel that I should use insulated metal plate instead of my hand but I have no one nearby...
DrStiffler
Quote from: forest on July 06, 2008, 04:29:36 PM
Dr Stiffler,
@forest
Sorry but I am not sure I understand your question and what you were doing, but let me offer an example.
A Exciter can do some very strange things with the local environment, under 10m and some interesting things at 1m or less. An example is the holding of a neon by one lead and touching it to the exciter. The neon will light and under conditions I do not understand, you can pull the neon away from the exciter and the neon will remain glowing as string as it did when touching the exciter. In fact I have a video where this can be seen. You can place the neon on a surface and it will extinguish when you let go of it. Some times you can pick it back up and it will light. The flip side is the times it will never work. I think when strange things start to take place its time to turn the video on.
Okay maybe I did ot answer the question as you wish. Maybe if you ask in a bit different way or with more detail I will get it. The more you work with one and the more you try, the stranger it all seems.
aether22
Quote from: DrStiffler on July 06, 2008, 06:45:00 PM
@forest
This is all so clearly a case of pulling and pushing fields by the aether, or creating aetherically boosted ion streams in other cases. (Boyd Bushman mentions in his patent how his aethero-magnetic beamer can increase the discharge of a VDG terminal from a fraction of an inch to many feet, similar conduction through dielectrics are noted in the TMB as well as others)
I assume when you mention that you can pull it away and it will stay lit you mean it was not lit without connection to the SEC beforehand?
This is essentially the same as one twin feeling what is going on with another twin, if you can energize the aether and create a link it will you will turn something which would have little or no coupling into a high coupling, interestingly you see low coupling situations in most FE designs.
Now one interesting question, if you make a coil and put a sine wave of a specific frequency through it, and make another coil to pickup it's signal, will you be able to pull or push signal this by adding a SEC to either the transmitter or the receiver?
It is quite possible the SEC will carry this other introduced signal.
Another thought is to add a magnet to a SEC powered motor and see if being SEC powered increases the coupling from the rotor magnet to a coil. (although this is assuming the rotor magnet becomes fully saturated by the energetic conditions the SEC creates)
I actually looked at Harti's and JLN's Joseph Newman motor research yesterday and it clearly creates the negative current they saw by enhancing the rotors induction of the stator coil.
Attached is one possibility that might just work if tried with a higher powered SEC.
forest
@forest
Could you post that video ? It is unbelievable effect!
Are you saying that you are able to lit neon first but keeping neon by one lead and touching exciter while second AV output lead is not connected to anything and then the same even without connection to the AV output leads?
Well,my experiments are so striking.The only thing I've already tested is a test with insulated plate.If I connect that plate to one of the terminals of neon and carefully adjust frequency, there is a sweet spot when neon is shining bright and flicker.Then by positioning a hand nearby the plate I can turn neon light off and by slowly going away the neon remains off  . Quite opposite,when I do this fast - the neon is lit again.
Connecting insulated plate to the second lead of neon seems to just rise a bit light intensity but much stronger neon light is generated when again I place a hand near the plate. I believe there is also a possibility to set such 'sweet spot' when neon is originally off and lights up only when placing hand nearby the plate.
Please excuse me if this is something normal but it was a really something new to me.Also I feel a kind of electrostatic field around the plate, something similar to what occurs near to the insulated HV cable  from car coil.
