DrStiffler
@Loki
With a clip lead short the ends of the lamp, you should see little if any change in operation.
Measuring with DVM at tube ends will read a DC voltage.
Great work, oh and a G2 or G3 in your basement lab will run lights all over the house. Down side is a Faraday Cage over the house to keep the FCC away.
All things are possible but some are impractical.
Loki67671
@aether22
They do in fact light from either end. It's strange sitting here looking at them glowing on the desk. LOL  8) Cool White!
@Dr. Stiffler,
Just as you stated sir. DC voltage with definite polarity. Clip lead across the bulb end to end makes no more difference than just touching or moving the bulb around. Clip lead bulb to bulb had same effect, very little. The bubble is quite large and a bulb can be kept illuminated just about anywhere on the black ABS sheet. Very interesting. I can not wait to light the FCC, I mean, faraday cage up....LOL
See the pix and once again very nice work. It was definitely worth being bitched at.
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
k4zep
Quote from: DrStiffler on August 03, 2008, 06:42:36 PM
@Loki
I wonder if this is a near field phenomena without much long distance broadcast.....What is the RF level/density from a G3 @ say 10 feet distance on any particular frequency?  If the G3 is ?? watts, could I light FL lamps all over my boat?
Teslas wireless lighting finally done????? ::)
Ben
tiltfulll
Hi guys I just looked into this thread!
I got one thing to say:WOW!
Could some one give me a summary and point me to the right direction so I can replicate?
Thanks!
aether22
tiltfull, Stiffler lists all the parts for the SEC 15-3, but your best bet may be to register your interest in Stiffler's 3rd generation SEC's ASAP.
IMO this is a very clear demo of fields being carried on an aetheric connection.
If it were a bubble, well you can't break a bubble for one fluro and not the other.
I feel this discounts the idea it's an energy bubble and strengthens the idea that there is literally a fluid stream from the carbon rod (or the water activated by the carbon rod?) to the fl tube.
The question now is what else can you have the stream carry? IMO there is much evidence that fields can be carried and these fields can induce power.  Very interesting that the more bulbs the brighter they lit and the less power it pulled!
I want to get one of these and run motors/buzzers and ferrite rods with pulsed coils run near this and see if these other fields can find coupling, hmmm, coils out over fl tubes to pick it up? too many ideas.
Ok, so if you or I just want to do these neat things right away our only option is to go with this part list:
Circuit Parts List for SEC15-3 and SEC15-20
Name Ident Manufacture Part#
Q1 MPSA06 JameCo 26462
R1 1.0M ohm 1/4W 5% JameCo 691585
C1 470pF 100V 10% X7R JameCo 332612
C2 0.01uF 100V JameCo 597281
C3 0.1uF 100V JameCo 544884
C4 10uF 50V 20% JameCo 10882
L1 10uH SRF 22MHz 130mA JameCo 372171
L2-L5 22uH SRF 10MHz 140mA JameCo 372197
Semi optional:
D1 1N4001 1Amp 50V JameCo 35975
D2-D9 1N4148 Signal/Switch JameCo 743314
N1 Neon 95VAC 1.9mA JameCo 1770744
LD1-LD9 UltraBright White LEDs Hong Kong BUWLC333
Obviously some of these parts and the AV plug aren't needed to replicate these demos with lighting the tubes.
And use the diagram in the image attached and breadboard it.
Of course an AV plug can be made to work by other setups and so possibly so could this, but that's too much uncertainty for me.
I'd also note that I am not saying that coherence as Stiffler states isn't occurring, merely that it's not the whole picture of what is going on here IMO.
