aether22
BTW my attempt to build a SEC from the plans was not successful so it's not a sure thing.
ramset
DR Stiffler   HHO  sounds great!!!  looks wild !!  can't wait for a vid  Chet
Thanks Grandma
AbbaRue
Any welding supply shop sells carbon welding rods.
They are called Gouging Rods.
I bought a box of 50 for $26.
They have a copper coating on them that you can just peel off, or maybe just leave it on.
If you know of a local welding shop they may even give you a few.
aether22
In Bens latest video http://it.youtube.com/watch?v=HBLcylzgoAI
He reports 60hz AC on the tube.
This is to me a sign that this can pull in fields with possibly greater power than may be otherwise expected.
But while I am a bit apprehensive to go into detail of all I have established, lets for the moment just look at what Stiffler shows us.
He shows that somehow a fluro tube by being connected (or possibly only close?) to the output of this can light up and then it is as if an invisible connection between the carbon rod/wire and the fluro tube, one tube can be connected while another is not.
But luckily he initially used a tube where one end had a blown filament, this tube would only work when the good end was away, at first I assumed that the blown filament was doing something interesting but when it was shown non blown tubes work just fine it became clear, the reason is that the filament acts as a receiver much as his hand did with the larger tube, the receiver must drag the field through the whole tube for the effect to work, perhaps this was obvious to other right off.
I wonder if a simple filament is as good as it gets or if there may be ways to enhance the connection by adding to this filament. (tuning cap or other tunable elements? if 2 tubes are better than one would 2 filaments not be?)
Another option is to see if maybe other things can be pulled in, such as abruptly changing magnetic fields from poorly shielded electric motors or buzzers or similar sources of leaky strong fast changing magnetic fields, these could I believe induce significant excess energy.
Also what could be used to possibly intercept such a field?
I will add that if you can identify where it connects from then you may be able to add permanent or DC electromagnets and even find this field carried along as there are a few such claims of just such DC magnetic field projection. This could turn a compass or maybe attract ferrous materials.
I will have to see if I can produce anything that can with far less efficiency create a similar electrical output, not sure I can wait for gen 3 SEC's.
For any that don't believe that Stiffler is establishing a special inductive connection between the far filament and something (the SEC, Antenna or EM flux in the environment or all of these) then how can you explain that one fluro can loose power when another is being powered? The only alternative is to believe as I suppose Stiffler believes, that the tubes are (after conditioning) extracting energy directly from space thanks to the SEC's conditioning of space and the tube. (but if nothing is being pulled why does it matter which filament is connected?)
At any rate it's one of the other (or both or something in between) unless current flowing through the air is seriously considered.
And the same question would be asked, is the current filament ideal or can you do better?
hmmm, I wonder what would happen if 2 differently tuned SEC's were used, would the fluros show preference to the SEC they were conditioned/attached to or would they continue working?
Enough questions from me, I think Stiffler more or less in private email gave his permission for this musing but I doubt think his policy has changed on suggesting experiments for others to do.
forest
DrStiffler
High frequency field from SEC + carbon rods . Interesting.
I hope you have Geiger counter somewhere .... (joking  ::)
Seriously , what do you thing about possible Vallee Synergetic PROTELF reaction inside carbon rod caused by SEC ? I hope it's not very offtopic here
