k4zep
Quote from: professor on August 06, 2008, 04:00:59 PM
Being a Licensed Radio Amateur myself (from the 807 Days)
you will know that rectifying any form of RF will provide you with DC.
A small amount of DC will cause electrolysis  particular in a conductive solution.
I have a great respect for Dr. Stifflers Circuit if used as intended, and therefore believe that it should not be mistakenly used to do something that can be done with straight DC ,unless the results are staggeringly different.
I am working on Stanly Meyers invention and believe that in principle  there may be a correlation ,furthering  new ideas.
I am not trying to be Critical of your experiment but it could lead others to be sidetracked.
This is just my Opinion and it is an opinion only.
prof.
Hi Professor,
You remember 807's?  Shack warmers!  Yes, I remember them well.....Go to YouTube and watch the last video I just put up.  The voltage drop across those 4 diodes MAX would be about 2.7/2.8 VDC in a low current rectifier mode.  Observer and marvel.......Glad to have a good Ham with an opinion aboard.  Dr. Stiffler's devices are real and explore the far reaches of wideband pulse RF.  Stanley Meyers theories are a great place also to mess around with pulse hydrogen generation!
See:  http://www.youtube.com/watch?v=NULf5fugi5M
Ben K4ZEP
scraven
professor - RF comes from ELECTROMAGNETIC waves. Stiffler uses the near field (via the high voltage exited electrostatic field). Similar concept but RF requires MORE POWER than a high tension ESF. If Stiffler was using RF it would be highly inefficient and pointless. This is NOT the case!!!
aether22
The more I think about this the more I believe it could be used as a Joe Cell, so if anyone with a SEC believes in Joe Cells then if you can get this water cap effect working then it might be very well worth a go. (IMO this field and Orgone are both just excited vacuum/aether/lattice and they may be close enough for this to work as a JC)
Lattice333, I'm interested in having you coach me through making a SEC run, I bought the parts a few days ago (mostly, cheated a tad on the caps) minus the critical variable inductor, not sure how/where to buy this and the tuning thingy. (core, coil, ferrite)
I am reasonably sure that's the issue with my attempt, the variable inductor.
I told someone I was chatting with about Stifflers demo with the fluros and they asked me a question which reminded me that maybe my flux pulling idea as explaining the Fluro demo makes more sense to me not only because I know of 30? say other devices/experiments that do the same thing reasonably clearly but because Stiffler did one of those with his SEC quite a while ago now.
He took an air core pickup coil and found the inductive field from the ferrite was uniformly detected by the coil and distance had no effect until at about a meter say it just went to zero like 'closing a door'.
The fact that the orientation and position of the pickup coil relative to the ferrite is critical means it's not just a scalar spacial energy bubble being tapped but the field from the ferrite, at least in my mind.
note: scalar in that sentence has it's original meaning and is not used to reference Bearden's theories.
stephenafreter
Hi,
First of all great congratulations Dr Stiffler, Lattice333 and others for this fantastic discoveries.
Pictures with all this fluo lighting are full of hope !!
Of course I want to jump in the experimentation, but am not expert. The circuit is surprisingly simple, the SEC15, and it has only two problems for me. On Lattice333 pictures I can see the coil and the kind of copper pipe, that I suppose is used as heat sink for the transistor ... but I'm not sure :(
Could anyidy give the specs of the small coil that is vertical with a white plastic tube as air core?
Aether22 gav a list of the parts and numbers from JameCo, but te coil and copper pipe are not referenced.
Again I'm very surprised, and after 5 years following the free-energy quest, I can say 'Waow that's it, Dr Stiffler found it, the simplest way to harness the space energy' ... first we have light !!! and ten I hope we can run an electric heater, that will heat houses and also be able to cook the daily food for zero pesos :)
For me electrolysis is not the best way, also it is a fire hazard ... all electric should be better :) :) quiet and non explosive !
Again a thousand of thanks and congratulations Dr Stiffler !!! You are writting the future !
MDG
http://radiant.100free.com
DrStiffler
All things are possible but some are impractical.
