k4zep
Quote from: k4zep on August 06, 2008, 04:48:02 PM
Hi Professor,
You remember 807's?  Shack warmers!  Yes, I remember them well.....Go to YouTube and watch the last video I just put up.  The voltage drop across those 4 diodes MAX would be about 2.7/2.8 VDC in a low current rectifier mode.  Observer and marvel.......Glad to have a good Ham with an opinion aboard.  Dr. Stiffler's devices are real and explore the far reaches of wideband pulse RF.  Stanley Meyers theories are a great place also to mess around with pulse hydrogen generation!
See:  http://www.youtube.com/watch?v=NULf5fugi5M
Ben K4ZEP
Hi Gang,
After I uploaded the above video, I realized I did not show regular electrolysis and the voltages and current that would develop with the 2 carbon rods in a normal setup.  Here is an extension of the above going from 2 to 10 VDC.....LOTS of GAS and LOTS of current.............
See:  http://www.youtube.com/watch?v=B7HKbPnVpBs
Ben
Loki67671
Thanks Doc!  ;)
You rule!
Here are the electrodes I'm going to try first and the batteries I'm putting on charge right now.
Results soon.  ;)
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Loki67671
Quote from: stephenafreter on August 06, 2008, 05:00:04 PM
Hi,
First of all great congratulations Dr Stiffler, Lattice333 and others for this fantastic discoveries.
Pictures with all this fluo lighting are full of hope !!
Of course I want to jump in the experimentation, but am not expert. The circuit is surprisingly simple, the SEC15, and it has only two problems for me. On Lattice333 pictures I can see the coil and the kind of copper pipe, that I suppose is used as heat sink for the transistor ... but I'm not sure :(
Could anyidy give the specs of the small coil that is vertical with a white plastic tube as air core?
Aether22 gav a list of the parts and numbers from JameCo, but te coil and copper pipe are not referenced.
Again I'm very surprised, and after 5 years following the free-energy quest, I can say 'Waow that's it, Dr Stiffler found it, the simplest way to harness the space energy' ... first we have light !!! and ten I hope we can run an electric heater, that will heat houses and also be able to cook the daily food for zero pesos :)
For me electrolysis is not the best way, also it is a fire hazard ... all electric should be better :) :) quiet and non explosive !
Again a thousand of thanks and congratulations Dr Stiffler !!! You are writting the future !
MDG
http://radiant.100free.com
2 - 20 uH variable inductor wound with 22ga or 24ga copper wire, I think I used 24ga but I'll have to mic it, the heat sink is 1/4inch copper pipe bent with pliers to be used over the MPSA06 transistor. Look back through these pages carefully, IT IS ALL HERE.  ;D
Best regards,
Jim
aether22
Back when Stiffler first found the effect (pretty sure it was quite new at the time) he sent me one of the cores he could get the effect with, and at the time anyway it wasn't every ferrite core would work as he reported on vortex-l.
I tried with that core at the time but my frequency gen. was not able to hit a fine enough frequency.
I tried that same radio ferrite loop stick and made it variable by sliding the core but got nothing, so my question is where do you get the ferrite, plastic parts and how many turns of wire is it? (I can try both wire gauges if need be)
Also if you can show a decent closeup birds eye view of the breadboard circuit I'll attempt to replicate placement so I don't get a screwey capacitance.
amigo
@Doc et al,
I don't know if the bulb just lit in my head now was it flickering for awhile, but it sort of dawned on me to raise some concerns regarding any biological effects that SEC could be producing.
Is there a way to determine the field strength, spectrum of frequencies and any possible biological effects that using the SEC might have? After seeing all those fluorescent lamps light up at distance without wires I thought to my self "wow, wait a second..."
I know that this might be not a concern right now for most, but many of us are playing with it and are sitting right next to the device...
