0 Members and 27 Guests are viewing this topic.
Loki67671
@All
When I get it right and can sustain a flame the cap will become aluminum. Then it should be no problem to make a power in measurement and a power out measurement by literally making over-unity tea......so to speak!  ;D No more working in a 58F lab for Loki!  8) 8)
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Yucca
This is a great thread! I'm impressed with the SEC generating HHO, it looks overunity to me! I am going to give it a go with my SEC15-1
COUNT ME IN FOR TWO OF THE NEW GENERATION SECS IF THEY GET BUILT!
@all
I have discovered that if I saturate the SEC15-1 output inductor (inductor just before AV plug) just right using a handheld neo magnet (1/4 inch x 1inch) then I can get very strong SEC output, I think it encourages the higher frequencies? Its best to watch a neon while you do it to find the sweet spot, only recommended with a heatsink on your SEC transistor. I think this might be helpful for all those going for fire.
pomodoro
I just finished my copy of Dr Stifflers SEC using a 2n3553 Rf transistor but there seems to be no difference to the output.
Shorting the neon caused the current to jump from 30ma to 70ma.I was hoping that the AV plug might power the neon with 'free power' using some new unknown mechanism. The next step will be to add more and more AV plugs and watch the effect on current to the oscillator.  If more plugs make the oscillator draw more current is there any hope for OU?
DrStiffler
Quote from: stephenafreter on August 08, 2008, 02:44:12 AM
Hey, I made an error about the third video, it seems to be an hoax ... but I found another video that demonstrates the hoax, AND in this latest video the guy shows electrolysis gas burning, AND the flame is the exact same bright yellow color as in SEC experiment :) :) so I encourage you to have a look.
Amazing! WATER CAN BURN! Use Water As Fuel!! : http://www.youtube.com/watch?v=Bs13jBWqFjA
sorry for the mistake, I'm so excited since 4 days I discovered the SEC thread ...  just can't sleep well since, SEC technology is just flashing in my head all night, and it never happened before. It must be our chance to get cheap and clean power, the answer of the quest !
Thanks Mr Stiffler !
MDG
@stephenafreter @All
Now I can be critical and condemning, why? Because the video mentioned 'I believe is FAKED' Why? Not because 3- 9volt batts could not produce HHO that might POP if enclosed until ignition, but primary reason is the second liquid it totally clear, where is the gas? Yes indeed it burns with the same color but where is the gas? To support a flame like that would take one milky looking substance and it would only last a second and make a loud noise. This is not HHO. It is not the complex gas that comes from other working devices.
There now said please don't be taken in by this high school demo.
All things are possible but some are impractical.
DrStiffler
Quote from: pomodoro on August 08, 2008, 07:16:35 AM
@pomodoro
Well I am not surprised at it not working. All of us on the thread that started out and build different models as the circuit evolved and many configurations were tried, all found that each replication seems a bit different and that was from the basic construction platform and different parts. The ones that obtained similar proto boards and coils were closest in duplication, yet small capacity differences made a significant difference in some.
The SEC 15-3 and 15-20 circuit boards are of precise design built around the transistor and other components, intrinsic to the board layout is certain parasitic capacitance that is required to obtain its operation from such a small foot print board.
You are not going to be able to just plug a VHF or UHF transistor into the design, up the voltage and get a SEC Exciter, if you can I want you on my team 'at once'.
I wish I could make it easy, but if you read through the thread you will see it can not be, at least not yet. G2 and G3 if produced is far more complex than the 15-3 and 20 and is indeed designed for two versions one of 10W and the other 15W. Of course the primary difference here is cost because of the special transistors I use. MPSA06's won't make the cut.
