jox
Hi Dr Stiffler and All, just a note to say thanks, off to get some carbon arc rods.....
aether22
Well this subject has likely been touched on many times before, but  most recently on page 59, posts 2326, 2330 and 2332
And in post 2359 of the same page we see that the 'lattice' if effected by the extreme bandwidth of the sec exciter.
So from the look of your nice clean signal you may not have it operating correctly, however if it works maybe it does not matter, see IF it acts the same way, so check out some of the suggestions in post 2326 and if it passes then being a tad pragmatic for the moment at least, who cares?
DrStiffler
@hartiberlin
I will send PM, but if you read this first; Please create 'locked' topic "Stiffler Ultra Efficient Electrolysis"
I will NO longer participate in an interactive thread. It takes far to much time to clean the garbage posted.
Thank you
All things are possible but some are impractical.
Kator01
Hi creator,
can you plese tell what kind of transistor you use and what hfe this transistor has ?
Also how many turns of your air-coil and if possible a circuit-draing.
I wonder how you get 3o mhz sinus when in your former post you write about 10 MHz ?
What about the power in ?
Also a strict warning about using the transistor 2N3553 : Specification reads : "... contains very toxic beryllium-oxyde ". If you blow this transistor and breathe in the smoke you will get a very dangerous heavy-metal-poisoning ! You will not be able to escape the room fast enough.
Kator
