0 Members and 38 Guests are viewing this topic.
creator
@All,
I made an error in the MicroSEC schematic on the http://creatorguy.com website.
If you saved a copy, please delete it and go back to http://creatorguy.com for the revised, corrected, and improved version. :)
-creator
Lattice333
@creator    Great web site - keep it up
Two observations to share;
1) If you reduce the amount of metal between the output choke and the load then, for the same output power the input current significantly reduces. What was that the Dr said about keeping stray capacitance to a minimum?
Carbon rod however does not load the exciter like metal does. This could have important design implications in building something bigger.
2) Charge a lead acid battery with a SEC plus AV plug. Leave the battery for a few hours and something like half the charge gained whilst charging has been lost.
Comments please.
ramset
Latice    Plengo [I believe] has been doing extensive sec battery charging research. He seems to feel his numbers are VERY good
Are you seeing diff results ?[I do believe Plengo made some changes to his sec]
Creator Sweet web site!! More
Chet
Thanks Grandma
plengo
@ramset
yes, I have been doing the load test for a little awhile now and it takes lots of time. I have also changed substantially doc's SECs to many variations. My last variation worked so well that I was impressed myself.
After a few runs, I noticed that I really burned a few chokes and that somehow made it work so well. I am in the process of replicating my "burned" SEC again and it is not easy, but I think it is worthy because it "really" did charge the battery very fast and with real voltage and power and with very, very little input power. Something about the diodes of the AV Plug and chokes being burned that made it work very well.
For now I will say that that experiment is in the "monkey science" phase because it is NOT what I can reproduce it myself and therefore the pictures and videos are on hold.
Fausto.
ramset
Fausto   you put a smile on my face with that post Thanks. Monkey science sounds interesting .I hope you can reproduce your additional effect    Chet
Thanks Grandma
