DrStiffler
Quote from: Lattice333 on September 25, 2008, 09:27:13 AM
Dr Stiffler,
great to see you are back online. I figured the hurricane got too close when your web site disappeared. Thanks for opening up the new section - lots of exciting ideas to check out there.
Can I ask a question about the safety of LED's? Your web site has the following warning "DO NOT *EVER* LOOK AT THE SUPER WHITE LEDs OR THE NEONS CONNECTED AS LOADS WITHOUT OSHA APPROVED UV PROTECTION. A SIGNIFICANT AMOUNT OF X-RAY CAN ALSO BE PRESENT AND PRESENTS AN EXTREME HAZARD."
Does this apply to LED's generally or only when they are powered by a SEC circuit? The reason I ask is that LED's appear to be the most efficient light source available (2-3watts producing the same light as say a 50watt incandesant bulb). Around the home it is tempting to take out the compact fluro's and replace them with LED compatible replacements. Your comments make me wonder if this is safe.
If you were to light your house with SEC circuit(s) and annoy those greedy power utilities would you opt for fluro's or LED's?
@Lattice333
I may have to retract my statement about X-Rays and remove it from the site comments, although what does it hurt to be safe?? I do not feel at this time that x-rays are a problem...
A good net search on the topic of LED's will provide you with the information on why you should not look directly into White LED's when powered to their intended levels. In addition you will find that LED's are not what you think in terms of 'Most Efficient', to the best of my current knowledge, this is not so. Your search and reading will offer backup for my belief. I would find the links for you but I know that it should only take a few minutes to get the info.
No, the danger is not caused by the SEC Exciter, it is the White LED itself.
There are far better ways to us a SEC Exciter than the driving of LED's.
All things are possible but some are impractical.
DrStiffler
amigo
DrStiffler
nickle989
