DrStiffler
Quote from: hartiberlin on October 26, 2007, 05:54:57 PM
I just made a few tests with this principle circuit
and made it much simpler.
You just need a ferrite choke , a signal generator and 3 blue or
white LEDs and a big metal mesh.
You can use the 3 LEDs to build the Avramenko plug,so you don?t need
the 2 x 1N4148 diodes.
This has the advantage, that the current through the 2 Avramenko rectifier diodes
also puts out light.
The whole thing is a resonance effect and probably a parasitric capacitive coupling to
the signal generator ground.
But with the right ferrite choke you can enhance the effect.
I have recorded a video and will try to upload it now here or
at youtube.
It is pretty long, so I guess I better put it to youtube.
Regards, Stefan.
Stefan;
So if you are using only LEDS are they all polarized in the same direction? Or is it a standard 'Plug' design and you have reversed one LED and it does not light? Don't the rectifiers on the plug take on the form of a full wave rectifier?
Waiting for the video.. Glad to see someone working on it.
All things are possible but some are impractical.
abassign
I have bought, through ebay, the "ferriteloop stik aerial" and hope to be able to receive them in a short time.  I have rediscovered the work done by JLN in 1999 (http://jnaudin.free.fr/html/afep012.htm ), is very like as Stiffler experiment and while I wait for the aerials, I will retry the JLN experience.
tefan, also you have made the JLN experiments ? If yes, can give me some advices ? Have the idea that there are many elements in council with the Stiffler experiment, elements which are not evaluated carefully of 1999.
The bigger difference between the two experiments is the frequency used for the oscillator, JLN uses 10 KHz, Stiffler, if I do not mistake, uses frequencies about 5-10 MHz.
How for almost all the JLN experiments, when the experiment giving the first interesting results, JLN cut off him,  having further details has not been so possible.
hartiberlin
My small ferrite transformer is called:
EFD 30/15/9
It has as core material N27 ferrite.
The coil I am using from it has 650 milliOhm DC resistance.
This ferrite transfomer has several coils on it,
but I am just using this one, as this gave the best light output.
So it is basically a ferrite choke.
I don?t use a transformer with 2 coils as Dr. Stiffler did.
You will see it all on the video.
My function generator normally only goes to 200 Khz ,
but I used a setting between the knob raster, so there the frequency
was much higher and I could go up to about 3 Mhz.
So all one has to do to scale this effect up now is
to use a very sharp edges pulse generator with very fast rise and
fall time and using just one wire output to go the right big ferrite choke
and then in series with the ferrite choke going to a few LEDs arranged as an Avramenko plug and then to a big metal mesh
or metal screen hanging isolated in the air, so it can catch free electrons from the air.
You will see it all in the video.
I have now converted the video also to an about 37 MB AVI file with DIVX.com codec
and MP3 audio sound.
I am now also uploading it to overunity.com into a subdirectory.
Regards, Stefan.
hartiberlin
Quote from: RStiffler on October 26, 2007, 06:37:20 PM
Stefan;
Yes,like the normal Avramenko plug configuration.
I am then using a wire at the one pin of the "output" LED to go to the mesh.
You will see it in the video, when I finally get it uploaded.
Google video did not seem to like my AVC codec from my camera,
so 170 MB upload was wasted. It can not convert it to FLASH.
Okay, now I upload it directly to overunity.com as the AVI.
Stay tuned.
Regards, Stefan.
hartiberlin
Okay, here already 3 pictures of the test attached.
Now my FTP program to upload the video is also "choking.."...
Murphy?s law again... Grrr... :o
