0 Members and 354 Guests are viewing this topic.
DrSimon
Quote from: derricka on January 29, 2009, 06:18:39 PM
@ Simon
Do you know if Dr Stiffler will be posting new findings here, or anywhere other than his own website?
#derricka
You may want to watch www.scribd.com as the Doctor is in the last edits of three papers he will publish there.
DrSimon
Quote from: amigo on January 29, 2009, 09:10:29 PM
Age ?
Doc can't be that old, at least from his voice it does not sound that old?
I hope he doesn't croak on us...there's still work to be done. :D
#amigo
I myself think age is a relative thing and to see DrS you would not think him to be 66 years of age - and yes he has a strong and caustic sometimes voice. He was doing very well until the last year and now the numbers are adding up. He will be publishing papers to www.scribd.com and I understand he is going to do a couple of videos where yo can actually see the man - that up to now has been highly protective of this type of exposure.
amigo
@DrSimon
I agree, age is relative and really part of our belief system/programming (and anything programmed can be de-programmed :) )
Please let us know when those documents are posted, as well as videos.
Thanks.
hartiberlin
Shanti
Boah, quite a lot of posts, since I last saw in this thread...
Short question @DrStiffler:
Did you every consider using coils for the rectification instead of the two diodes?
E.g. like Tesla did explain in his US Patent Nr 413353: Method of obtaining Direct from alternating currents.
It could be interesting if there would be any difference...
The basic principle in short:
Namely to wind two coils on a permanent magnet. This actually means the core is already saturated in one direction. Now if you pass a current through a coil, so that it's field goes in the same direction as the core field, the core, as it is already saturated will not influence the coil, so that it behaves just like an air core coil. But if current flows in the other direction, it's field will diminish the field of the core, so that now the core is not anymore saturated for this direction, which means, the coil now behaves as a coil with a core. And as usually cores do increase the inductance of a coil by factors of 1'000 times and more, the impedance in one direction is > 1'000 times bigger than in the other direction. So by using two coils in different directions one can rectify AC.
