slayer007
Quote from: PaulLowrance on November 20, 2009, 08:04:40 PM
That helps. You wrote that L1 has 22 turns around 1/2 pipe. Also you wrote L2 has 35 turns around a 1/2 pcv pipe and can range from 22uh to 60uh. So I'll know which ones you're talking about, can you point out what inductor A, B, and C are relative to L1, L2, or Lb?
http://globalfreeenergy.info/imgs/slayer007-circuit-q1.gif
Thanks for the help!
Paul
C is a ferrite bead its part of the filter.
B is L1
A is L2
L3 is missing.It would be on the collector of the transistor.
An AV plug is there in it's place.
gadgetmall
Quote from: DrStiffler on November 18, 2009, 04:01:09 PM
@gadgetmall
How can you sleep at night? What allows you to say I (ran) from anywhere? I left OU.com and yes I have left EGF because of Dysfunctional BS, just like your far from factual statement than I (up and runned).
Ever wondered what facts and civility could offer??
Dr. Stiffler . please Don't get mad at me. I apologize and did not mean to offend you . I have a different perspective on things that's all . Sometime My mouth gets in the way . I did flatter  you Sir . You have an interesting device and i like it . And so i Am again Sorry . Please accept My Apology  . I will try to remain Silent and ask My questions from someone else . I don't type or think in syntax because i am not a programmed computer :) I am Curious and extremely interested in powering Circuits from the lowest possible Voltage and MA's . I would like to power your circuit from a 1 volt battery if its possible to have any gain . I have built the first AA powered nichrome wire heater from a joule thief .It charges a Large 650 farad 2.7 volt capacitor up to full capacity and leaves 3500 AMPS to do work . while the AA battery only drops a measly 5 1000's of a volt and powering 1 watt worth of LEDS.  I Would like to see efficiency from your circuit do the same and will attempt to charge one with it .
And to answer your first question . After being a Dad and mom to a 7 year old Girl ,Inventor ,Experimenter,grandfather to 4  i say the lords prayer and Sleep very Well  .
And Question 2. What "Allows"me to say you ran . Up and run in a south "syntax" IS you left . .
Kind  Regards
Thanks
PaulLowrance
slayer007,
On numerous times I've asked you a particular question, which you have ignored. And then I asked the question in a PM. You've logged in over 1/2 dozen times, no reply. Please tell me if you don't want anyone verifying your claim of two dead 9V batteries (~ 8V each) charging a 80 AH car battery. That is a huge claim that if true could be the smoking gun.
Thanks,
Paul
PaulLowrance
I'll try my best to make out slayer007 entire circuit, and the results of this replication will be posted at my blog site,
I'm posting the above url so people can see the end results on the slayer007 replication because the "free energy" community is a funny thing in that the people who seek the truth often get banned because one often must eventually be blunt if they are to try and get the details.
Paul
gadgetmall
Quote from: PaulLowrance on November 21, 2009, 11:26:36 AM
slayer007,
Thanks,
Paul
Hi Paul .Its very possible he is seeing gain . I have demonstrated over the unity of a primary source in the Jule thief thread . from an aa battery 2500mah i have charged an ultracapacitor to full capacity with only a few microvolts of loss from the battery 1.4 volt battery . I have stored 3500 AMPS that burn wire and produce HEAT while producing light at the same time . this Amperage is not cold electricity . The worlds first aa battery nichrome heater / light schematic is on page  997 thru 1002 and there is an ongoing experiment . this is easily replicated and you can build one in about 5 minutes   . i do not own an ampmeter to measure the output amps on the ultracapacitor however if you read the last 8 or so pages i can brightly burn  nichrome coils  while lighting up two .5 watt 5 chip leds . i welcome replications as it is easy to do.
Gadget
