hartiberlin
Hihi,
that was a good one with the Geiger counter ! ;) ;D
What frequency are you running it amigo ?
Do you have to tune it for the right frequency, so the LED
lights up this bright ?
Many thanks for this video.
Regards, Stefan.
amigo
Quote from: hartiberlin on October 26, 2007, 11:36:50 PM
Hihi,
Regards, Stefan.
:D
I get 11.21MHz on my Fluke 124 scope, but the frequency is all over the place because the signal generator is not filtered of noise. I did have to tune it so the LED lights up most bright, it's pretty fineky at best.
I tried measuring current but am not sure if my equipment is sensitive enough. Fluke scope shows 0.4mV across the 1ohm resistor, as described by doc.stiffler in Fig.09, but I do not know if that's real or not.
Also, I do not have the high voltage effect present on the other end of the coil. Not sure if I wired it in a wrong way (geesh how many ways are there) but the neon bulb does not light. If I touch the end the LED goes out...
I'll keep at it, thanks for the encouragement :)
amigo
Just wanted to add, frequency seems to change a bit, depending on which end of the coil I use and also if I reverse the L2 and L3...still no HV on the free end.
hartiberlin
@amigo
what is your voltage peak to peak output at your oscillator circuit
before going into the coils ?
I also wonder how Dr. Stiffler gets so high high voltage outputs
at his ends of the unconnected coil wires..?
He must  have a very high Q of his resonant circuit.
Maybe he really has very good cores and his Q is very high.
P.S: I tried it with a 220 to 15 Volts transformer made from
normal iron and this also works , if you ground
one side of the output LED.
I used the 12 Volts winding as the one wire choke.
Then it also works with lower frequencies at around 1 Mhz.
But the light output with the ferrite choke is still higher
at its resonance frequency.
Regards, Stefan.
Freenrg4me
"I have made a video, especially for that paranoid delusional freak who's name I won't mention and his followers, but everyone is welcome to watch it...it's educational !"
@ amego
Dearest amego,
Delusional paranoid freak here, I noticed that your frequency generator chip only goes to 10mhz, not 21mhz. I also noticed 4 wires going to the board, not 1 wire. So you have not activated the core and that should be evident by the fact that you admit it.
Maybe if you activate the iron at 21MHZ you could do better than barely lighting 1 LED? Hardly a replication of a circuit that has not been verified by anyone including you.
Also, when Stiffler was logging in as other users and pretending to be someone else, he sort of blew his credibility forever with anyone that has some. How do I know that you are not just one of Stifflers minions or Stiffler himself? If Stiffler is even his real name... That we shall know soon enough, it is under investigation.
Is that one of those home made counters that you make from a phase locked loop? Impressive. Hit the core with 21MHZ like Stifler claims and shows with his scope shot and at a high enough power level and it just might detect something, if it works.
Until then you have not replicated anything and only proved that you have poor reading comprehension skills.
Believe me, I really wish I was wrong, I want to be wrong. But here is a reality check:
Stifler claimed few will show you a working cold electricity circuit.
Stiffler claimed it was over unity.
Stiffler claimed barium core necessary.
Stiffler claimed 90 degree opposed winding key.
Stiffler claimed this and that and every claim Stiffler has made, Stiffler has retracted.
Congratulations, so far that you proved a coil can induct with one wire if the frequency is high enough. Sorry to bust your bubble but that has been known for nearly 100 years.
Nice false attack but you only exposed yourself more.
Nice try.
