0 Members and 44 Guests are viewing this topic.
FreeEnergyInfo
hartiberlin
Is Dr. Stiffler still running this video:
http://www.youtube.com/watch?v=TXYY7TqS380
via any power supply or does he just excite it
via this ground coil only ?
If this is really running only by hooking up this ground coil
and everything else is just resonance and no battery or
any other power supply input, that is really amazing.
I have read that he uses a special transistor with a special
negative resistor characteristic curve...
Does anybody know more ?
Many thanks.
k4zep
Quote from: hartiberlin on February 20, 2011, 08:04:50 PM
Many thanks.
  Yes, its still on Youtube.  Its what he doesn't show that is so aggravating.  He doesn't show starting it or show that it is a self starter.  He doesn't disconnect the ground and show that it stops and/or restarts during this process.  He doesn't show the resultant voltage on the rails of the Osc. while it is working (which I suspect are very high, bulging caps, blown LED's), or the current in the Osc. while running (which I suspect at resonance is fairly low).  Then goes entirely opposite of the wideband effect and he shows it locking in on one frequency while operational which shows resonance in the whole circuit.  To add insult to injury, he comes up with a Propriety transistor and of course no one but him "knows" what it is.
IF it is as shown, and I have no reason to believe it isn't, what a excellent example and demonstration of his SEC theory.  That he has been able to prevent run-away by loading the collector of the "transistor" via a AV plug, which de-tunes it under load with resultant negative feedback at that point, he is thus able to sustain a stable balanced operational system.  I suspect he has found a very high voltage transistor with negative resistance characteristics similar to the 2N2222 that when the fold back from the output, isolated via the 2 L3 coils, the third to ground, is phased correctly via resonance into the AV plug, results in OU from the SEC theoretical near field around the device.  The SEC provides the field but a lot of other theories have to fall into place for it to work and that is the genius of Stiffler.
Ben K4ZEP
hartiberlin
Quote from: k4zep on February 21, 2011, 07:24:36 AM
Ben K4ZEP
Hi Ben,
yes, if that really is a selfrunning system I applaud Dr. Stiffler for his success.
I hope he will soon publish more about it.
Looking forward to see more of it.
As it is not running on the FM transmitter frequency, that
transmitter seems to have low impact on it, but maybe it helps to excite it
when it is started.
I hope he will soon share more insight into the circuit.
Yes, could be, that he just uses his N2222 transistor
wrong polarised so it acts as a negative resistor.
Maybe it is just something like a Mini-Kapanadze device
drawing the energy from the connected ground ?
Regards, Stefan.
Regards, Stefan.
