0 Members and 28 Guests are viewing this topic.
k4zep
Quote from: k4zep on October 30, 2007, 09:29:08 PM
There is obviously anomalous couplings in this device relative to large mass objects (our bodies, etc) and is to be expected I think.
Would be funny if some day it proves that we (our bodies, beings) are the key to everything and causing all kinds of things to happen :)
[/quote]
Actually it is capacitive coupling between you and me and the front end of the circuit, detunes it as we move around, I'm sure Dr. Stifflier could be much more specific in addressing this problem.....Probably need decoupling chokes in the circuit or shielding......although this is about as simple as you can get.
Ben
amigo
Quote from: k4zep on October 30, 2007, 09:46:44 PM
Ben
I did notice that happening and it was irking me because my crummy make-shift function generator is not good, so every time I'd adjust the resonant frequency the circuit would go out of resonance when I moved my hand away from the board.
Although my comment was related to more aetheric matters :D
hartiberlin
Quote from: amigo on October 30, 2007, 09:49:55 PM
Ben
Amigo,
do you use any blocking caps on the power supply lines ?
Use a few 100 nF caps and also a 100 uF cap on the power supply
lines at your circuit, so the power supply voltage stays stable.
This will help to avoid the frequency to get detuned.
This is very important with RF circuits.
Regards, Stefan.
amigo
Quote from: hartiberlin on October 30, 2007, 09:57:01 PM
Amigo,
Regards, Stefan.
Hi Stefan,
Actually, I am knowingly using Gel and standard batteries so these kinds of problems shouldn't occur, no?
Thanks.
hartiberlin
Hi Stefan,
Thanks.
Surely you need this also with just using batteries !
Even more, cause batteries have higher inner resistances !
