0 Members and 37 Guests are viewing this topic.
Grim
Wow, what an amazing thread!
I have been reading the whole thing today, and I am astounded.
The work on replicating Stiflers device is incredible.
Reminds me of my first introduction to electronics, when I was a cub scout.
Back then is when I was first inspired by an electrical device, and the same feeling comes over me now when I read this thread.
God bless you Stifler, and good luck.
I will watch from the sidelines, with bated breathe, as this gathers momentum.
hartiberlin
Just came back from
www.segor.de
and bought a few 40106 hex inverters
2.2 uH coils and some smaller pF caps for my
oscillator.
I also had a look at the LTC 1799,
but man, is this thing small !
Too small for my soldering iron and
I could not handle this thing with my
hands.
It costs there 3,80 EU per piece.
If somebody would have a circuit board for it,
which I could buy, maybe this would be an alternative,
but for now I am trying to use just the 40106 hex schmitt trigger
IC.
Now I might get a higher amplitude with using 15 Volts supply.
P.S: Ben can you try your setup please with modifying your coil-
magnet core combination and tell us, what change will still work and
what not ?
We need to get to the parameters, which really produce the power amplification.
Many thanks.
Regards, Stefan.
k4zep
Stefan,
Will wind an air core coil this evening 7-8 EST and report. My core not is not removable on the Ferrite magnet as I wound it directly on it with no paper/slideable insulation as I wanted as close coupling as I could get.
Just puttering around now waiting for parts to come in.  I agree that LTC is a Little Tiny Chip..........wow......
IF the device is working correctly, you should see elongation of the waveforms from the BF which I suspect is where the extra energy comes from........I still have a bunch to learn, I wish I knew 1/10 what the good Dr. knows!  All the questions we have are old hat to him..  Any test of a circuit takes 20-30 min to get all the measurements down exact and crunching the data.  I really am curious if there is anything else that will excite the way BF core does and provide this output.
REMEMBER you MUST have that L/C input series resonant device between the driver/generator and the BF coil for it to work properly  and it must be at resonance for maximum output.......at least that is a start.  The funkest thing is the possibility of a negative resistance or inductance reported by Dr. Stiffler with the BF coil on his inductance meter.  I have to look into that!!!!
Ben K4ZEP
Quote from: hartiberlin on November 02, 2007, 02:22:22 PM
Just came back from
www.segor.de
oscillator.
hands.
IC.
what not ?
Many thanks.
Regards, Stefan.
hartiberlin
Quote from: k4zep on November 01, 2007, 05:15:15 PM
Hi all,
Look at pix attached.  1 led in series with the input, 10 LEDs on the output. Input and output single wire.  Oh, I live in a reinforced concrete building and I am in the middle of it.  FM or AM radio just don't work where my mini shop is (Worlds smallest lab). I have been through about 100 variations in the last hour and half, learning as I go. My Sig generator is 27V pp output floating as I have removed the ground connector on plug but of course there is inductive coupling to ground but all is floating right now.
Ben
Ben,
please can you test, how much dependend the output brightness  of your LEDs is
on the used signal generator voltage level ? 27 Volts pp ?
What, if you used a lower driving voltage ?
What frequency do you use ? Which is the best one ?
Can you go as low as 4 Volts peak to peak to drive it and
have still the LEDs lit the same brightness ?
hartiberlin
Quote from: k4zep on November 02, 2007, 03:19:56 PM
Ben K4ZEP
Okay, yes, I did not have this LC resonance circuit yet between the oscillator and the core.
But now have the right parts hopefully,but I only got 330 pF and 470 pF foil caps , no 400 pF silver cap...
Well, back to the table to work now on it.
Regards, Stefan.
