0 Members and 27 Guests are viewing this topic.
hartiberlin
Yes, the Rload in his circuit is his incand. bulb that is energized
every second once, when the cap is full via the 555  chip 1 Hz generator.
Hmm, Ben, do you also get at your AP LED a DC voltage, when you don?t have
a cap there ?
Normally I would have expected a pulsed DC, but I have a pure DC without a cap there,
just looked with the scope only directly at the LED...
Hmm..radio frequency circuits are really strange sometimes..
k4zep
Quote from: hartiberlin on November 04, 2007, 04:11:45 PM
a cap there ?Yes I do, enough parasitic cap. @ 10 MHz to integrate the pulsations.  Cap will also charge up if you replace the LED's with it.  Just watch out, voltage can get pretty high on it.  Mine goes above 100VDC in several seconds.  Dr. Stiffler's must be a barn burner to charge over 600uf to 120V in 1 second!!!
k4zep
Quote from: mramos on November 04, 2007, 05:24:17 PM
So a 555 with nothing on the threshold, discharge and trigger runs at 1hz?  News to me.  But I do not use them a lot.That part missing but standard pots and cap.  Short on time. (Inverted)
The the other side of the circuit is the osc. OK.
It does not matter still as VCC and ground you can see the input current and Rload the output.  And no telling what that 555 will do floating like that.  Circuit imcomplete, look at photos, you will see what is missing.
This is a long way away from the first couple circuits, but still listening..  Just glad there is no function generator hooked to it.
At least now it is getting to a point where I can build one, after I see more components on the 555 :)  Still like to see values on the schematic for L1/L2/L3 as well.  I have to antique radios (AM only before FM) that I do not need.
And Stefan said it worked as well without the core.  This still the case? I have not pulled them out :)
DrStiffler
Really! If you need help in making a 555 pulse 50% duty cycle, 2 R's and one capacitor. Please don't waste your time with my circuits, this is the simplest part of any of them.
All things are possible but some are impractical.
smoky
In Dr Stifflers circuit above the Emitter seems to be shorted to the Base divider network.
It looks like a Colpits oscillator so I guess it shoud be open at this point?
Smoky
