0 Members and 25 Guests are viewing this topic.
AhuraMazda
hartiberlin
Hi Ron,
this was a forwarded email from the person you bought the AM coils
from....
So he checked his cores and said, that they might not contain any Barium.
I am in this moment not at home, so I can?t check until the weekend, if my
cores have already arrived...
DrZLowe7
Mr Stiffler
I wanted to stay anomalous in this and just wanted the error on the schematic posted.
But since you used the word "crap" I must reply.
The oscillator built around Q1 is very typical and is most common in micro watt FM transmitters.
1) Is not Q1 an oscillator? Do not transmitters use oscillator's?
2) Does M1 not buffer and amplify the output from Q1. Because it is biased off it still switches on and off at the input frequency? Sounds like a buffer amplifier.
3) Does the output from M1 not drive the coils L1 and L2 . Sounds like an antenna to me.
4) Does not L2 receve the output from L3. Sounds like another antenna to me.
5) Does not D1 and D2 and Cp make a voltage doubler?
6) Does not the 555 do nothing but turn the load off and on?
7) Because the load being pulsed at a 50% duty cycle do you divide the output wattage by 2?
For any one that wants to try. Using the above schematic with R2 and R3 not connected together connect the end of L3 directly to ground because it has a capacitor at M1 output it will not hurt anything. Next connect a capacitor about .01uf or .001uf from ground to the end of L2. This will improve performance
I have not made this circuit but I know my stuff. If you have a working protype try the modifications and let me know the results.
My rods contain no Barium according the manufacturer it has Ferrite with Zinc Magnesium binder. I never said their was no such thing as Barium-Ferrite. But that it is not used cores or torids used for RF cores.
Buy the way if Stiffler denies any of questions above I will try and prove it anyone interested.
Any circuit no matter how complicated it my look can be broken down into its individual functions buy doing this you can discern how it works.
HopeForHumanity
"Dr. Stiffler states that the iron core on the coils had Barium in it. I have been in electronics since I was 13 years old and have never heard of Barium being used in a ferrite bar."
If you didn't mean what I think you did in the above statement, then why did you waste your time stating that you were ignorant of barium ferrite bars? Seems kinda stupid... lol ;D
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
DrZLowe7
Just some more thoughts from my last posting.
3000 volts was quite high maybe 300 volts for xenon bulb.
You also may want to try this the 1.1uh coils in the collectors of Q1 and M1 change to one of my 680uh coils or 470uh coils. Replace C2 with a 100pf capacitor you may leave C1 in or take it out next replace R3 with 1K. Replace C7 with .01uf . Remember to use the schematic posted a few postings ago as there are so many around with numbers for the coils and componets differences.
Also use the modifications sudjested in my last posting. But change the .001uf capacitor from the end of L2 .01uf.
1.1uh coils will most likely produce around 20MHz since free air coils of in that range have self resonate frequency around 40MHz. 1.5MHz to 3MHz or so should work just fine.
