0 Members and 27 Guests are viewing this topic.
hartiberlin
Okay, I was wrong.
The new cores are not better than the cores I already had.
These are the litz-wire coils which are better !
It seems these coils have a very high Q, so if you use them as a choke
at the output of a square wave generator and you hit their resonance frequency
they just put out a very high voltage.
In my case still 200 Volts p-p  at around 1.3 Mhz at the input (in front) of
the 2 avramenko diodes from 12 Volts p-p square input.
Other coils don?t have such a high quality Q and thus you don?t get this high voltage
which lets the LEDs shine brightly after the Avramenko plug.
I just recorded a movie, as this shows it much better than just pictures.
Still have to convert it and then post it.
Stay tuned.
P.S: All the effects are very dependable of the RF properties
of all the used components, so also an aluminium backplate of the eperimentation board
matters a lot and I urge all experimenters to test it without an experimentation board
and just use a normal PCB, there you will have different stray capacitances and this
will matter big time and you might wonder, why you don?t get it to run there.
Also you need to have the right wire length between oscillator output and coil
and avramenko plug.
Seems standing waves are also important at these frequencies...
not so easy this circuit concept...
So I will switch now to the EMdevices circuit.
DrStiffler
I have posted a new oscillator that works very well, 'The Thomas Oscillator'
It uses a single transistor and when the start resistor is properly selected and used  with the coils as I specify it is very effective and can drive 36 Ultra-Bright White LEDS while being very OU.
Take a look at it, no excuse for not using it, this is a great driver. http://www.drstiffler.com/ce4.asp
Oh and you .....  the day is close where the Jester be known :-)
All things are possible but some are impractical.
DrStiffler
Current status of SEC, 'Spatial Energy Coherence'. It now appears that I have been partially in error, in that the coils 'Do Not' determine the OU effect, yet they can enhance it. What that means is that I now have information that replicators have achieved OU when using air core coils. This does not mean that you should in anyway ignore what I have published, as it does present the best and quickest way to obtain the desired end result.
Air core coils may work, I can not say from experience, all I can say is that the cores and coils I have specified, 'Do' when properly configured display OU. If you want to go in other directions, then you are indeed on your own and your negative feedback is not relevant.
Do it how I have presented it and you will see the desired result. If you play the cut and paste type of construction, you are only fooling yourself.
Associates (6) in all around the world have duplicated the OU condition to the extent that there is little doubt that it is real.
Do it right and join the team, do it your way or be a 'Lip' server and so be it, your out of the loop.
Freezer
Quote from: RStiffler on November 17, 2007, 05:16:07 PM
"One of the initial problems in starting this approach was the light lost from the sides of the LEDS due to reflections in their plastic enclosures. The first of many solar cells proved to be less than efficient. The one shown above was made from film and was highly reflective as can be seen on the the proto-board directly below the LEDS."
You might find some good leds, and lenses here to get more efficiency.
http://www.luxeonstar.com/
Might also want to look into GaInP solar cells.
DrZLowe7
I will try and answer everones questions.
@Stefan
Any coil will show this action it will what I call "Ping" many times maybe 20 times or so this is very dependant upon the "Q" of a coil. This is way a crystal oscillator circuit works that uses a overtone crystal. For instance if I apply the output from a 1 MHz crystal to a coil tuned to 7 MHz it will produce a stable output of 7 MHz. This works like pushing a swing the first push is strong and starts the swing moving after the swing swings 7 times you give it another push.
A coil will "Ping" many times however after it's 7th "Ping" most of it's useful energy will be diminish  that is why overtone crystal oscillators stop at 7 , 5 or 3 overtone "Swing". If you notice your scope reading you will see the diminished power from the initial pulse to the 7th.
As far as the coils go the manufacturer most likely purchases the raw materials for there coils form someone else. It is very unusual for a manufacturer to make most of their own raw materials.
@dean_mcgowan
Business is not booming as far as coil sales go. I searched my records from 60 days ago from about the time I noticed an extra amount of coils being sold. I have sold about 115 coils that were purchased with out other radio items. @$1.87 each I am not becoming rich. If there are 100's of people trying to make these they are not buying from me. I count about 15 different people. I also stated in an earlier post that a coil from your AM pocket radio would most likely work as well.
@mramos
Yes I mean the 2.2uh coil. If it is critical I assume again it may because you are adding another 2 capacitive sources to ground from plug into the ProtoBoard.
To reply to your other posts. Yes some people do care about function. Aren't you glad to know the power is not coming nothing.
There may me something to extra "Pinging" from the coils. There is no magic here as to function. As to self running LED circuit again I telling about function. If you were left to believe the power came from nothing I could tell you it came for from the 5th dimension and you would have to believe me as you could not disprove me. And again I believe Location is in important. I was taking the "Magic" from its function as I think some were starting to believe the source of RF was coming from some unknown source. The source is not unknown but the POWER over 100ma is.
