Questions for Bob with no images attached
Started by eldarion, October 12, 2007, 05:02:15 PM
eldarion
All,
I have started this thread so that we can communicate with Bob without crashing his Internet browser.  Please do not attach any images of any kind here! ;)
Bob,
I put a transformer secondary (must be at least 1 Henry) as an HF choke between the filtered HV potential supply and the secondary winding, but the DC potential still does not seem to have any effect on the output.  My estimated COP is somewhere around 0.1, pretty bad! ;D
Can you see anything else wrong?  I have even upped the voltage on my MOSFET drivers to 10V highly filtered DC to see if there were any problems there.  I have been running frequency sweeps from 10KHz to 50KHz, and at no point does the COP increase.
Also, maybe another clue, changing the phase slightly does not increase power on the output.  When I have the DC potential circuit charged, the core doubles or triples its audible noise output, but the output waveforms look exactly the same as before I charged the DC potential circuit.
My output circuit right now consists of the 120V inverter feeding a bridge rectifier.  There is a large electrolytic capacitor across the output of the bridge rectifier.  Positive HVDC goes to the HF choke, and then from the choke to the secondary winding.  The other end of the secondary connects to the 0.68uF mylar capacitor, and then the other end of that capacitor connects to the load, which then completes the circuit to Earth ground.  The negative HVDC terminal also connects to Earth ground.
On the input side, I have three of the primary coils, equidistant from each other, with all of the CCW ends connected to +13.8VDC.  The CW ends go to the respective pulse generation MOSFETs, which are set to a pulse width of 5000ns.  The ground of the signal generator is connected to Earth ground as well.
Just wondering if you might have some more ideas for me to try... :)
Thanks!
Eldarion
EDIT: I wanted to see if switching time might have been an issue, so I connected my 20ns rise/fall time MOSFET drivers directly to the primary coils in open-ended mode.  The HV potential still had no effect, even with those beautiful pulses on the input. :)  Not really sure what is going on here; maybe I can call you tomorrow (Saturday) and we can hash out what I am doing wrong?
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bob Boyce
I'm good to go for a phone call today if you wish.
Bob
eldarion
Bob,
Could you PM me your phone number?
Thanks!
Eldarion
-- Thomas Paine
Bob Boyce
Bruce_TPU
@ Bob
Just a big thank you for helping Eldarion out.  We will all keep this thread clear of any images, to ease all communication, for all the replicators, as they run into any future challenges.
Cheers,
Bruce
