jeanna
Quote from: Localjoe on February 07, 2008, 08:24:13 PM
@ Jenna
You said-
Joe, I need to know if these tests were done on a device with AND without the secondary windings or if you were just reading or not reading the secondary.
jeanna
confusing question?
How many devices do you have and how many are you testing?
See, I get nothing on a lot of the same places you do. It is just on the one that has a secondary that the inner core 4 shows voltags. It shows 60.9mv between the terminals 5,6.
Localjoe
@ Jenna
yea kinda confusing.
Just the one i am describing the prior models i built had improper insulation and weren't wound with love.. nicely.
The readings i took were from just the wires on the primary coil no secondary was present while i was taking those readings. copper to + iron to - on the meter. those readings ranged between .7 -.9 v and between 16-20 ma.
ok  then i wound some wire real thin probably 24 plastic insulated from the top down i only got about half way or less because i ran out of wire.  next i take the leads from my meter and connect them to either end of the secondary doesent matter.  then i take in my hands the wires from the primary and make and break them myself.. i see a small  AC voltage and AC current on the meter..  this should help you understand my logic  :)
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
sid10
So
If I now understand the water is what holds the voltage or power or whatever it is that is creating our meter readings in the primary, until we probe them with a meter? It's working as an insulator?
Sid
The only dumb question is the one that goes unasked.
Localjoe
@ Sid
We dont know how yet but we do know what we've found and what makes sense and what doesn't so time will tell.   No one really knows what happens magnetically here other than ive found about the ac readings in the secondary after pulsing the primary on and off.. if you have the ability to build a rotary gap like you described earlier with 6 points or 4 that should work great for inital testing once you have your secondary wound.  :)
Localjoe
@ jenna
You did put it in water to get it moist right?
