Localjoe
@ Jenna
Mine has been in a plastic ricotta cheese container with water from the start i never used a sink or anthing bills is fine because its ceramic but jenna you might be shorting yourself out.. with that bolt to ground how i dont know but try in plastic container on table and if still no luck breakdown and use cotton fabric :)
@Bill
That idea looks nice in concept a lot segments is the main point you described , but i think its gonna be a pain in the ass with wire for now jsut try the foil if your making one and smooth it the best you can i think that will be much easer just to get started with . :)
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Pirate88179
@ Joe:
Thanks.  "A pain in the ass"?  Hey, after winding this new coil and keeping everything insulated and untangling my wire spools, making this thing will be a walk in the park.  Ha ha.
An easier method might be to use something similar to a pc board kit.  Place the electroplated mastic material over the cd, or whatever, disk and etch out the interruption lines as you would when making a board.  It would be flatter and you could easily keep everything symmetrical.  Just a thought.
@ Hans:
I have not seen you here lately.  I hope you are doing well.
jeanna
Quote from: Localjoe on February 09, 2008, 04:01:56 PM
@ Jenna
                                                              Joe
All right, Joe
What exactly am I supposed to be trying to find. I have similar but lower readings. I think it makes sense because I have less metal.
You don't think it makes sense for some reason.
The idea that I am shorting out by using the steel of the sink does not make any sense to me. I cannot understand what it is that you think is so unusual about what I am doing?
Please explain yourself. And don't assume anything, just tell me what you want to tell me.
thank you,
jeanna
supersam
jeanna,
i know it doesn't make alot of since, but i ran into a situation in my manufactured home, doublewide, as they call it here in alabama,  where i got a shock, like a static shock, only contstant,  from a small cut on my arm, to the stainless sink.  i never really worried about it, or really thought about it at the time.   have you checked the voltage on the sink?  if there is any, it might be throwing your readings out of whack.  just give it a try.
lol
sam
ps:  keep up the good work!!!
Bruce_TPU
Hello guys and gal,
I couldn't help myself, and while waiting on other parts for the magnet motor, I have begun to wrap my earth battery.  I am very excited about the direction of things and Joe's revelations of the Stubblefields patents.
What will happen on the output side of the secondary when these babies are in the ground is anyones guess.  I will be a part of finding that out.  I will be wrapping my secondary with LITZ wire, 675 individually insulated strands of wire.  I already have it.
I have nearly finished my first layer of wrappings, and I am planning five layers.  It is the mother of all earth batteries, being 18 inches in length, with a 1/2 inch core made of Iron.  I wanted to be true to the patent and see if I see a difference compared to the Zinc bolts that others are using.
Cheers all,
Bruce
