0 Members and 40 Guests are viewing this topic.
jeanna
Quote from: Bruce_TPU on February 09, 2008, 09:00:12 PM
being 18 inches in length, with a 1/2 inch core made of Iron.  I wanted to be true to the patent and see if I see a difference compared to the Zinc bolts that others are using.
Cheers all,
Bruce
Thank you, Bruce
jeanna
jeanna
Quote from: supersam on February 09, 2008, 07:09:37 PM
jeanna,
   have you checked the voltage on the sink?  if there is any, it might be throwing your readings out of whack.  just give it a try.
lol
sam
ps:  keep up the good work!!!
Thanks Sam, I have been taking most of my indoor tests using a jar (various jars cuz I made 4 cells) on my table. It was only that last one that gave slightly higher mA readings that I used on the sink just to see if it meant anything.
Thank you,
jeanna
PS How would I check the voltage on the sink? between the sink and the stove about 2 ft away it is about 225mv. The sink is attached to the septic and ground by plastic pipes coming and going. The stove is electric. The house rests on 2 steel I beams that are anchored to a concrete base. It is a faraday cage too - covered in metal. Cell phones turn off and declare there is no signal when they are inside my house.
If you can figure out what it means please say. I haven't a clue.  Thank you  j
Localjoe
@ Jenna
Ive told you 5 times what i think  ;D again use some fabric and forget the tape i think that is hindering your results adhesive forms a minimal watertight barrier when it is pressed on to a surface.  I would really try something like fabric, cloth or those tube things i found at the diy audio store.  I think your current readings meaning amperage are being limited by your insulator on the copper.  and i would just use a plastic container to rule out the sink thing.   Since we dont know what the bolt does yet i would assume that it may not be a good thing to let other metal come in contact with it.. For control reason's while testing.
@Bruce
Im happy you have rejoined us-  coil looks good and hopefully you secure some great results.
@bill
Good thinking about the pcb stuff... what about that little pen that looks like paint but is conductive ink. so you can draw circuits, radio shack sells them  i think.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
jeanna
Quote from: Localjoe on February 10, 2008, 01:29:25 PM
        Joe
WOW what a good idea
One of the old time recipes for ink is iron and tea.
The mixture of the tannic acid with the iron make dark black stain. but if it is iron it will be conductive or magnetic.
cool
Freezer
I got some materials today, so I will give it a try.  I couldn't for the life of me find bare iron wire, or pure iron rods, so I got the regular bolt. (I know Jenna..hehe)
I've been very interested Leedskalnin lately and rereading his book over and over.
I found these two paragraphs interesting..
"Transformers and generators are making the currents in the same way,
by filling the iron core with magnets and letting the iron core push
them out and into the coil."
"Connect the battery with electric magnet for a little while, now
disconnect the battery, connect the light bulb with the electric magnet the
same way it was connected with the battery, now pull off the six-inch long
bar, do it quickly, then you will see light in the bulb."
Its interesting he also states that the energy is already in the wire, relative to what SM said about "kicks".
