Pirate88179
Another view of the primary.  All 100% cotton insulated.
jeanna
OK I didn't want to make a whole post about my name but oh well,
Joe, and now Freezer,
I call myself Jeanna. You could write it jean-na, but don't bother. It is pronounced like the Italian Gina.
OK?
jeanna :D
Localjoe
Fine then
My name for all future references on this thread is Johnny Foongats
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
jeanna
Quote from: Bruce_TPU on February 09, 2008, 09:00:12 PM
Bruce
Bruce,
NS states on p1 lines 13-15 that he is making a constant primary current but also an induced momentary secondary current.
Is the presence of the heavy iron bolt keeping enough magnetism going in the system to make the secondary the essentially useful part? or would you say that the secondary is there just to feed back to the primary?
Do you suppose the momentary secondary current is so fast that it would seem constant?
jeanna
Bruce_TPU
@ Bill & Jeanna
I hope it does produce some power.  But the real test is with the secondary being pulsed under the ground.  It makes me think of an AC transformer, self powered, mixing with the Telluric currents under ground.  How it will all shake out is anyones guess.  Later we should tune the coils with a cap, to resonate at the frequency we are pulsing the primary.  I also have some other simple ideas, but first things are first.   ;)
I have completed three layers of wrappings and I am starting on the fourth layer.  I am off to buy one more thing of copper wire.  Total copper and iron wire will be 63 feet, each type of wire, at the end of the fifth layer.  Very tedious work wrapping the copper wire, but I have high hopes!  (as always!   ;D )
Cheers,
Bruce
