jeanna
Quote from: Pirate88179 on February 11, 2008, 12:28:03 AM
@ Jeanna:
That makes sense to me.  If you take a nail and wrap copper wire around it and attach a battery to the wire, you have an electromagnet. (I know you already know this)  So, what we have here is the small galvanic action or possibly something inherent in the bifilar windings that will create a magnetic field.  My coil also influences the compass.  I believe I posted that earlier somewhere when you first brought this to our attention.  I have not tried shorting the cu and fe leads but it moves the compass anyway. Bill
Yes, thank you,
I think that if the people trying to make and break a magnetic field (Joe and Bruce at the moment) assume that there is not one, they will possibly be thrown off by the fact that there is one. I don't have a clue how to break up a magnetic field that persists, but that may be a necessary part of the break part of the design.
Yes dry-ish, It may be that they are only barely moist, but I think I noticed this before I wetted the #2 coil which is only a primary with 3 1/2 layers. and mine produce so little voltage. What about the rest of you with more substantial voltage. I assume the more voltage, the more force in the constant magnetic field that must be considered in the break design.
Any questions anyone? It is confusing to talk about these coils. I think there is built into these devices an inherent constant magnetic field. I would like to hear if this is true for everyone's devices.
thank you,
jeanna
PS I think the car story is on icehouse or cheniere websites
Pirate88179
Thanks Jeanna and MrSpates.  Here is a link I found to the Tesla electric car.  fascinating reading.
http://keelynet.com/energy/teslafe1.htm
hansvonlieven
I am OK guys, thanks for your concern, just a few issues to battle with at the moment.
Be back full on shortly.
Hans
Bruce_TPU
@ Bill
You are quite correct about the relay.
I want to attempt to use my micro TPU to power it.  It has a runtime of 39 minutes from the touch of a battery.  I can increase this time to days, simply by switching the cap to a super cap.  I can loop back the earth battery power to keep the thing running forever, it requires such a small amount.  Anyway, it may not be the best way, but it will be the quickest for me, to give a proof of concept.
EDIT:  The micro TPU pulses DC.  at low frequency.
@ Joe
Of course I understood you tested it and showed voltage on the secondary.  My whole little premise was: What happens under ground?  None of us know that yet, so I was simply speculating on what might or might not happen.  I know we will see voltage on the secondary.  But will it be considerably more buried?  That is yet to be seen.  I hope so, of course.   ;)
Cheers,
Bruce
Bruce_TPU
Quote from: MrSpates on February 11, 2008, 12:55:04 AM
@ Bill
I'm sorry Bill, I lost the link. The story was about where he took a friend out to an old barn somewhere, and there was this car ( a bearcat?) anyway it had a 30 hp electric motor in place of the gasoline engine and it had a six foot antenna on the back. He wouldn't tell his friend exactly how it worked, but he put some cylinders in a box under the dash and turned it on and let his friend drive it around the countryside and through the city. Claims it went 90 mph. They then returned the car to the barn and Tesla removed the cylinders, put them in a suitcase and left. That is the best I remember from the story. Perhaps someone here can direct you to a link. The best I can gather is he was getting energy from the air much like the drawings of his free energy generator, and running it through those cylinders and that was what powered the car.
@ Mr. Spates
No antenna!   ;)  Wire, 12 Vacuum tubes and resistors!
"At the appointed time, Nikola Tesla arrived from New York City and inspected the Pierce-Arrow automobile. He then went to a local radio store and purchased a handful of tubes (12), wires and assorted resistors. A box measuring 24 inches long, 12 inches wide and 6 inches high was assembled housing the circuit. The box was placed on the front seat and had its wires connected to the air-cooled, brushless motor. Two rods 1/4" in diameter stuck out of the box about 3" in length.
Mr. Tesla got into the driver's seat, pushed the two rods in and stated, "We now have power". He put the car into gear and it moved forward! This vehicle, powered by an A.C. motor, was driven to speeds of 90 m.p.h. and performed better than any internal combustion engine of its day! One week was spent testing the vehicle. Several newspapers in Buffalo reported this test. When asked where the power came from, Tesla replied, "From the ethers all around us". Several people suggested that Tesla was mad and somehow in league with sinister forces of the universe. He became incensed, removed his mysterious box from the vehicle and returned to his laboratory in New York City. His secret died with him!"
EDIT:
@ Jeanna
You are correct.  My core is bone dry and magnatized.  That is interesting...  I have to think about that.  I have one more layer to wrap, tonight.
