0 Members and 189 Guests are viewing this topic.
Bruce_TPU
Hello all,
Back to the bench.  I retested my voltage (dry) and it is .02 volts.  No ma's.  The following pictures make no sense to me, especially where the compass points away from the coil on the right side where you see  most of the fourth tier of winding.  Each picture is titled with it's description.
I need to finish winding now.  Will check in later.
P.S.  I bought my relay from Radio Shack tonight.
Cheers,
Bruce
Edit:
Well, I have run out of copper wire, again.   :(  I have one half of the fifth and final wrap to go.  I have so far used 75 feet of iron and copper wire.  I probably will use about 15 feet or so, more to finish.  I also have used 2 yards of 100% cotton and need 1 more yard of material.
I will finish tomorrow night and place it into some water for a voltage and amperage test.  I will then remove it and wind my secondary onto it.
Freezer
Winding this thing is hard.  :-[  Weird that it can hold voltage being seeming completely dry.  I'm getting about .3 volts without having even wet it.  Maybe its the moister in the air or capacitance.
jeanna
Quote from: Freezer on February 11, 2008, 10:37:24 PM
Nice job. It looks authentic!
I agree winding them is hard.
Before you add any magnets, Freezer, please take readings all around the thing the way Bruce, did. This way we will be able to compare similar compass readings.
Beautiful job esp with the spool.
Thanks,
jeanna
Bruce_TPU
It looks good Freezer!
I see that you are not running your layers in series.  I think this is good.  You will be able to test with them in parallel.  I am curious as to what the differences will be.  Mine are all in series as everyone knows.
Cheers,
Bruce
Freezer
Thx guys.  I hope its worth the winding hehe.
@Jeanna
I will take some readings all the around once finished.
@Bruce
I was thinking that each should flow in opposite directions to each pole at the ends.  I will try hooking it up each of the 4 ways to test.  I could go on forever with the layers, I guess I will max out the two wooden ends though.
