0 Members and 187 Guests are viewing this topic.
Bruce_TPU
@ Freezer
Great results!
1.)  What size is your center bolt and is it just zinc plated steel?
2.)  What type and gauge steel wire are you using?
3.)  What gauge copper are you using?
4.)  Your results were with all of your ends wired in parallel?
5.)  Have you tried to wire them in series and see the difference?
Thanks!!
@ All
I think the problem with my coil is my core.  I am going to purchase two new cores this afternoon, and wrap only one layer and test, before adding more layers.
@ Joe
The Radio Shack relay that I purchased, only requires 18 ma's to operate but at 5 volts.
Cheers,
Bruce
Freezer
Quote from: Bruce_TPU on February 13, 2008, 03:51:12 PM
Its a 1" x 12" bolt, but I'm not sure what its made of.  Its seems like its zinc plated.  I sanded it, and it came to a dull silver color.  I'm using 14 gauge wires for the primary which are about 6.5" wide on the bolt.  Not sure what the zinc coated wire is made of either.  I just tried it in parallel, but will try later in series.  I used marine epoxy to hold the ends on the bolt.  You don't want it to stretch and short out later.
hansvonlieven
G'day all,
Why are you guys not using a ferrite antenna rod for your core? Mine is round, is 18 cm long and is 9mm in diameter. These rods are soft ferrite material (They will not become permanent magnets after use in an electromagnetic coil as hard ferrite does) and have virtually the same specs as soft iron. They are available in two lengths here. Should be available at Radio Shack or equivalent.
I have put a piece of shrinkwrap tubing over mine, shrunk it and wound my coil on top. Works a treat.
Hans von Lieven
Localjoe
@Hans
Come clean.. Where did you hear to use a ferrite core? Im sticking with the iron for now but would love to hear your results what have you got going there>? ;D
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
hansvonlieven
G'day Joe and all,
Ferrite stands to reason. I have been trying unsuccessfully to obtain soft iron of sufficient diameter for my coil. I do not want to use steel as steel becomes magnetised after a while and I need a new field like a hole in the head.
I know that some coils and some transformers use ferrite as cores (High voltage transformers in TV sets are a good example) So I decided to try it.
As to my results, you have to wait a little while as I am pursuing a different line of inquiry to you guys. I do not use galvanic current, my coil is plain iron wire and lacquered copper wire (0.5 mm diameter) wound bifilar. I have not added the secondary coil yet. Instead of using galvanic current I use a 1.5 V small battery to energise the coil.
Early days yet, so have patience, I will let you know if I strike something out of the ordinary. Time is a limiting factor at the moment unfortunately.
Hans von Lieven
