Bruce_TPU
Hello all,
Well, I have wound a baby coil, one layer.  It gave me .710 volts @ 1.25 ma's.  I will wind another tomorrow.  I want to test an idea outside with them.
Then I started on my second coil, taking apart my first one.  This has a 5/8" core by 16" in length.  Galvanized bolt.  I wrapped it with damp cloth between layers, and only wrapped two layers before testing.  I am using 14 awg galvanized wire with my copper.  Galvanized works.  and is rust proof.  My other coil has already put rust stains all over it's wrapping.  Galvanized will not rust.  Hmm....How long will it put out power?  Years?  Not too shabby.   ;)
Damp cloth reading:
Volts
.770
Amps
35.2 ma
Wet bath
Volts
.725
Amps
32 ma
The amperage increases when standing on end with wires ends to the bottom.  increased by about 7 ma's.   ;D  (This is when it is out of the water!)
Tomorrow I will wrap two more layers and then test again.   ;D
Slow but steady progress.  I can see the instruction booklet now, "When planting earth batteries, mulch well."  LOL
Cheers,
Bruce
Bruce_TPU
Hey guys and gal,
I just wired my baby coil with my mega coil, in series, and got 1.56 volts!  Tomorrow I will try two baby coils in the ground and see if they can be wired in series or parallel underground, without shorting each other out.  I will wrap each completly in cotton.   ;)
Cheers,
Bruce
Pirate88179
@ Bruce:
35 mA.....nice going!  I can't believe you took your other one apart already.  That's one heck of an improvement though. I don't think we will have the problem with shorting in the ground in series because these coils are self-contained units not depending on another electrode some distance away.  When I can get the time and materials, I will wind another larger one and keep my other two for series experiments.  Great idea with the galvanized wire.  Mine is also showing signs of rust. (Rust never sleeps)  So, galvanized core and wire should give long life.  Of course, if Hans's ferrite core works, that will never rust or break down.  Great progress being made here. We will get there.
@ Hans:
Thanks for the explanation of the hard and soft ferrite.  In our machining world we were just concerned with actual hardness for fabricating the parts, not the electrical properties.  I learn something new here every day.  Thanks.
Pirate88179
@ All:
Below is copied and pasted from 2 responses to my earth battery video on youtube.  I think we ought to try this as well sometime.  It is similar to what Joe did a while back but, I didn't know the battery would not run down.  This appears similar to the effects seen on the micro tpu topic.  What do you all think?  I invited him to join us in our efforts over here.
Hey bill if you hook any Battery to the earth batt. and hook a light not an LED. it will burn and not run the battery down as long as it is hooked to the earth battery.tesla new this I bet! I just had to tell you what I learned from you aaaand stumbling across this phenomenom ! Thanx Again! Go Earth Power! Take what you need and the earth will replace it.
uncleshorty (1 hour ago) Show Hide Marked as spam
0 Poor comment Good comment
Reply | Remove | Block User | Spam
Hey Bill I put copper plates in the ground 20ft. 1/2in. copper wire 24ft.long run south then I plundged a 3ft long 4in aluminum pipe into the earth only2ft.deep. I then placed a 12volt batt.between the pipe and the end of the wire.between the +batt and the pipe A sm. elec. motor the same between the -batt. and the copper wire. both motors spin. I then hooked up three 12v. lights to the battery still 12.5 v. Its like pumpig out a boat with a big hole in it the battery is a cap. equal reaction US
hansvonlieven
This is fascinating stuff Bill
Well Done !
Let's see what we can do with this little puppy.
Hans von Lieven
