0 Members and 169 Guests are viewing this topic.
hansvonlieven
Quote from: Pirate88179 on February 14, 2008, 02:22:22 PM
@ Hans:
What do you think about my above remarks?  I realize this branch of research may be a little off topic but then again, maybe not.  How is your coil coming along?
G'day Bill,
I don't think you are off the topic at all. This area must definitely be investigated further.
Hans
BTW I am trying to get my hands on a camera so I can show you my coil.
Bruce_TPU
Quote from: Pirate88179 on February 14, 2008, 02:41:31 PM
@ Bruce:
Here is a modified version of your drawing showing how I believe we can use the coil cells for this.
Hi Bill,
Yes, your drawing is exactly what I hope works also.  This is something we must investigate right away.
Do you remember yours and my test, where we hooked a nine volt battery to the earth battery and the voltage and amperage jumped?
With no diodes, I see the current not only flowing to the load, but also flowing to the ground and then from ground back to the battery.  Almost like a capacitor on an L/C coil.
If this turns out to be true, it would be incredible....!
Now we must verify.  (So little time, so many experiments!)  Remember to use a regular low voltage bulb and not an LED.
Tonight I will finish winding three more layers on my coil.  I am hoping for 75 ma's.  I do not know how many we need, but that should be a good start.
@ Joe
I wonder what would happen if you placed your little discovery, between your primary and secondary of your Earth battery.  Then you would be sending High voltage pulsed into your secondary.  It would be a good test, since the rest of us have low voltage, high current to pulse.  We can see which is more effective, underground in garnering those Telluric Currents.  What kind of relay is it?  Did you get it from Radio Shack?  If so, what is the number and type?
Cheers,
Bruce
EDIT:
I am speculating now, but perhaps the way Stubblefields battery works is the same, as if we hooked up a battery as we plan on testing to see if it stays charged.  Perhaps as the secondary is pulsing, it begins to act as an electron pump as well?  We will see.
Pirate88179
@ Bruce:
I agree 100% with what you said in your last post.  I think the guy's (who replied on youtube) analogy might be brilliant:  Like bailing out a boat with a hole in it, the more you bail out, the more water flows in.  I have been thinking lately of experimenting with some solar cells along with our earth battery experiments.  I have been reading up on the latest in the solar area and this little discovery, again if true, could put that technology out in front of many others as it fixes a main drawback of that technology; no power generated at night or on cloudy days.  At one of the electronics supply/surplus sites Joe posted a while back, I found some amazing little cells that put out .9 vdc @ 2.0 amps!  These only cost like $4.00 ea.  I have seen solar panels (consisting of many cells) costing many, many dollars that don't put out that much.  Anyway, like you said, so many experiments, so little time, and $$.
Localjoe
@hans
Anytime  ;)
@Bruce
The relay is homade just like shown, i used 4 layers of the green "magnet" wire from Radio shack for the 4 inch bolt i wound it on, i think that was steel.  The metal thing that resembles a spring board is a coping saw  blade about an eight of an inch wide and probably 5 inches long
the contact above it looks like a nail but i dont have a nonmagnetic metal to use in skrew or nail form so i was just holding a peice of thin copper wire (stranded) gently on the saw blade and it starts vibrating rather quick never hits the electromagnet below it either just up and down in mid air.  It only took like 20 mins to build .. umm i have power tools that helped me a bit tho  :)
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Bruce_TPU
@ Bill
Please repost that link for that cell, or PM it to me.  I would appreciate it very much.
@ Joe
Thanks!  It sounds like a great little relay.  I can't wait to see how it does hooked to your coil.
@ All
I just ran a great little experiment!
Setup:
Carbon tube is North - Positive
Galvanized Spike is South - Negative (both have been in my yard for awhile. )
Voltage reading from this "couple"
.824 volts
Amperage reading from this "couple".
.12 ma
My "baby" coil, (Completely wrapped in cotton, to insulate!!) Buried 6 inches North of the carbon tube.
Voltage reading of "baby" coil
.710 volts
Amps reading of "baby" coil
.6 ma
NEXT:
I wired the "baby" coil in SERIES with the carbon and galvanized couple.
Volts
1.4 volts  ;D  (Cotton is the perfect insulator for these things!  We should be able to put as many in the ground as we want!!)
Amperage
2.2 ma's          (WHERE DID THESE EXTRA MA'S COME FROM?   ??? :D ;D ;D  )
SPECULATION:
The small baby coil, acting like a battery hooked to the "couple" in series put power into the couple and MORE power came back!
Of course we need many, many more tests, but I can not tell you how encouraged I am!
Cheers,
Bruce
